separating door panel material
Old Jul 7, 2012 | 01:55 PM
Gtpguy's Avatar
How do I separate the material from the door panel without destroying it? I want put a cloth door trim in its place. So then how would I reattach it? Hot glue, a big stapler, what?
Old Jul 9, 2012 | 03:34 AM
summers_Z28's Avatar
Re: separating door panel material
if i remember right (did it a while ago to change window motor) but i think what i had to do was there are a few screws by the door handle / utility buttons, undo those, pop out the window up/ down and power locks utility pad, and unplug it, then it's just a matter of pulling it off.
Old Jul 14, 2012 | 02:08 PM
Gtpguy's Avatar
I need to reword that, I need to remove the material portion from the panel.
Old Jul 14, 2012 | 10:40 PM
bbreeze93's Avatar
I would try prying it off slowly and maybe adding a little heat to help separate it from the glue. Find some adhesive spray. I know loctite makes a spray.Get something that can with stand the heat from in the summer with windows rolled up. tape everything off. Spray both surfaces that will make contact and let it cure...
It may be easier and cheaper to just trade with something or buy a panel that already has the piece your looking for
good luck
Old Jul 17, 2012 | 10:23 PM
Gtpguy's Avatar
They didNT do my color combo from the factory. So im frankensteining some.
2QUIK6
Sep 17, 2016 02:31 PM
karpetcm
Aug 14, 2015 03:02 PM
michael42869
Parts Wanted
Aug 3, 2015 10:22 AM
RX Speed Works
Jul 24, 2015 02:25 PM
ducttape1975
Jul 10, 2015 06:29 PM
