Removal of 4th Gen tailights
Old Aug 22, 2006 | 12:29 PM
Papajoe's Avatar
Trying to removal 4th Gen tailights to spray nite shades. Anyone give me the procedure for this removal. Thanks.
Old Aug 22, 2006 | 01:05 PM
CamaroRacing12's Avatar
Re: Removal of 4th Gen tailights
its fairly easy....2 hand unscrewable ***** behind each taillight in ur trunk under the carpet..... light pops out....twist off the bulbs and the taillight is removed.....i do suggest if the taillights r not brand new that u re-seal them with clear sealer....moisture in the taillights is a biatch and loooks really crappy! good luck! any other ?'s post em up
Old Aug 22, 2006 | 01:46 PM
MrShipoopie's Avatar
deffinitly re-seal the lights the seals go quick
Old Aug 22, 2006 | 05:56 PM
Papajoe's Avatar
Thanks CamaroRacing12
I only found 1 **** and I knew something else was holding it in. I will look for the other ****. Thanks again.
Old Aug 22, 2006 | 06:10 PM
Blue89Bird's Avatar
just pull down the grey plastic/carpeting stuff. There are wing nuts hidden all the way along the far corner towards the quarter panel.
Old Aug 22, 2006 | 06:27 PM
94_PatriotRed_Z's Avatar
if you still have your spare tire, the one on the outside will be hard to get to on the passenger side
Old Aug 23, 2006 | 01:56 AM
oneslowz28's Avatar
when you put them back in just push on the taik light and tighten the wing nuts just finger tight and when u let the pressure off they will be tight enough to not move and you wont have striped the plastic wing nuts out
HOFFICER
Apr 6, 2020 10:36 AM
R@mpage
Apr 20, 2015 10:02 AM
ad356
Apr 11, 2015 11:12 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
