Questions about Painted Calipers...
Old Dec 27, 2002 | 12:42 PM
Ernster500's Avatar
Question Questions about Painted Calipers...
I am getting ready to paint my brake calipers. I have a can of base paint and a can of clear.
Can I do all four calipers with one can of paint?
Thanks, in advance!
E
Old Dec 27, 2002 | 12:51 PM
pu12en12g's Avatar
Yes you should be able to do it with one can. Light coats are the key.
What paint are you using ?
What prep did you do ?
Are you using high temp clear coat ?
Old Dec 27, 2002 | 12:56 PM
Ernster500's Avatar
I bought one can of PlastiKote's Brake Caliper Paint (Red).
I am planning on wire brushing and sanding them. I also bought this metal treatment stuff that is supposed to prep it for painting.
I did get the hi temp clear.
Does that sound ok for the project?
Old Dec 27, 2002 | 03:07 PM
Marky82's Avatar
I used the plasticote red paint, wire brush, sanding and this rust remover called naval jelly. Mine came out good just make sure that you prep the calipers well, good luck
Old Dec 27, 2002 | 03:20 PM
tireburnin's Avatar
Make sure you spray the rotor too. If you have enough left over, spray some on the base of your wheels too. I did that with my honda, and it turned out great.
Jk, make sure you post some pics when your done, I am doin mine soon too.
Old Dec 27, 2002 | 07:12 PM
Ernster500's Avatar
LOL, I was going to ask you for pics!
Old Dec 27, 2002 | 07:54 PM
stik6shift98's Avatar
i used 2 cans......of high temp red
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Patricklt1
Apr 24, 2015 06:29 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ModdedNerd
Dec 14, 2014 10:28 AM
