painting question
Old Jun 6, 2005 | 03:39 PM
fya95camaroz28's Avatar
painting question
i have a 95 blk z28 that was repainted like a year ago. i have a new hood front cap and fenders now.what will i need to paint that like primer.base coat.clear.list everything i will need to paint it i mean everything lol.i have the paint both spray gun etc just need everything else.my unkle is doing it what are the steps to do it?how many coats of each?do i need to wetsand/buff?thanks help me out please.also wheres a good place to get paint?
Old Jun 7, 2005 | 12:13 PM
Z28SORR's Avatar
Re: painting question
Look in the yellow pages and find the nearest Automotive Paint Supply Store. The guy there will be happy to fix you up with every thing you need including a book on how to do it.
Old Jun 7, 2005 | 12:32 PM
WhiteboysZ28's Avatar
Ya call your local paint store , you`ll need
Base paint , clear , hardner , reducer, primer , reducer, stir sticks , mixing cups, 1500 sand paper to wet sand for that glass look after the clear is dry then rub it out the whole car thast about it.
JOSH
Old Jun 8, 2005 | 07:57 AM
i found house of kolor base black will that match pretty good?
Old Jun 8, 2005 | 08:02 AM
my unkle sprays foam everyday and theres a paint booth at his shop.for the primer imm be useing a 1.6mm tip for the base/clear imma be useing a 1.3mm tip is that ok?how many coats of primer/base/clear will i need?
Old Jun 8, 2005 | 12:58 PM
Im going to tell you now that house of Klor paint is expensive & is very hard to touch up my bike is painted house of Klor Kandy red awesome color but expensive I have about $500.00 in just paint on my bike. As for the black just buy a standard Omni black cheap but great paint easy to spray , also Omni makes a sweet clear just thin it out 10 percent after adding the hardner. as for primer I dont know 2-3 coats then wet sand it baby butt smooth , paint a good 3-4 coats clear another 3-4 coats that way you can wet sand it smooth , everyone has there own opinion but I paint all the time & this works for me.
JOSH
Old Jun 8, 2005 | 03:36 PM
thanxs man any other tips?
Old Jun 8, 2005 | 05:06 PM
JUst take your time dont rush your paint coats give to base coat a good 15-20 minutes between coats , when you clear give time also depending on the temp a good 10-20 minutes also so its tacky , like I said dont rush it or you`ll redo it , LOL
Good luck.
JOSH
Old Jun 9, 2005 | 09:59 AM
cool thanks ill keep all this in mind
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Patricklt1
Apr 24, 2015 06:29 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ModdedNerd
Dec 14, 2014 10:28 AM
