My 97 Z4C project...A Work in Progress
As always want to thank ALL who have replied and given me encouragement! For me this IS a slow process due to nature of the way I work and my issues with being **** in doing this.
A few pics to update as to where I am at now. Still haven't started her up yet as I got sidetracked into completely redoing the entire underneath of the car before I can put it all back together! Only thing I have done is turn the crank over by hand. Only things I still need to order are Lowering springs, new carpet, stainless brake hard lines, Stainless exhaust (decided to go true duals with X pipe and bullets to the CME) and other than some new bolts here and there, and few odds and ends I already have everything ready to go. Interior is completely out now as well. So slow but sure.
I decided to completely sand the entire underbody, prime with POR-15 and completely paint it with POR-15s Whitecoat. Other than a few places to touch up where I have already painted, all that is left is the rear wheel wells, top from above the driveshaft tunnel to the rear bumper area. This are still need to be finished sanding and primed/painted. I hope that my efforts are worthwhile in the end. It takes some time to do this right but should last a long time as well. Of course car will not see weather either and is garaged so should be easy to maintain. I have also decided that once done I am going to repaint the car and reapply new decals and clearcoat over them so they wont peel in the future as well. So here we go...
Powdercoated Upper Control Arms
Powdercoated Lower Control Arms
Spohn LCA Relocation Brackets Powdercoated
View of Underbody after completely sanded with a coat of Black POR-15 Applied. POR-15 Whitecoat being applied around edges. You can see where I left off.
View of Underbody after completely coating over POR-15 with Whitecoat. Still some places to touch up but you get the idea as to what i am trying to do now.
View of Drivers side rear
View of the driveshaft tunnel
View of trans tunnel area. new rear tailshaft seal to go in as well. Zip lock bag works good to catch trans fluid in jacking it up and down. Soon as I can get four new bolt will remount powdercoated trans crossmember and get rid of that dang jack that has been in my way for a few weeks now lol!
View of Passenger Side Underbody
Drivers Side LCA/frame rear area
Re: My 97 Z4C project...A Work in Progress
Your project is great and the modification you done on your car are also looking awesome. The engine is looking many times better now then before and rims are also prefect match with the car.
I notice from your IP address that you are from Pakistan. Are there many Camaros there?
FINALLY installed black powdercoated Trans crossmember and got that dang jack out of my way! Also, installed a new tailshaft seal, and a new O-ring in the speed sensor prior to remounting the trans.
Another view from side. Installed the powdercoated heat shield as well. Felt good to reinstall something versus the months and months of removing parts upon parts upon parts! I have just about everything on shelf awaiting to go back on...Soon! Plan on once she is back in working/running order again to replace trans pan with a chrome one as well.
At present sanding underneath from rear fender wells to the rear of the car (pics to follow in a few days). Majority is sanded now just need to finish the nooks and crannies...ugh! Just be glad when I finish sanding/priming/painting to begin putting her back together again!. I want to get her where I can start her up, then worry about getting the rest of her together. So priorities are finish sand/prime/paint. Then install fuel tank and lines. Install the radiator and AC condensor, fill radiator, install PCM, fire her up! Then install rear end/driveshaft, front end steering/suspension components, get her back on wheels and off jack stands. Then finish off interior. Then take and have alignment done (trailered of course). Take to shop to have stainless true duals with X pipe to Sweet Thunder Bullet mufflers to the CME exhaust tips. Then take and have stripes removed, repainted, new strip kit applied and then clearcoated. Won't have to worry about stripes peeling again! Then finally, take to Cincy Speed in Cincinnati, Ohio and have dyno tuned. So there is the plan...I'll be glad just to get her done by end of April...that is my goal and I plan to make it!
