Issue after kyb agx and strano install...
Old Sep 7, 2010 | 11:53 AM
UnVmySS's Avatar
Well, I installed these about 5 days ago and all the fender wells measure about 26.5 inches from the ground except the passenger rear, which is about 25.5 inches off the ground, meaning its lower than the front, and the other rear side. The stranos and kyb agx were brand new. There is nothing heavy enough in the back rear to drop it that much, does anyone have suggestions? By the way, heres some pics..
Old Sep 7, 2010 | 11:54 AM
UnVmySS's Avatar
Old Sep 8, 2010 | 10:39 AM
Z28SORR's Avatar
Measure it again, with at least 150lb. in the drivers seat. How much do you weigh? It is completely normal for cars to sit low on one side, or one corner. If you want it level your going to have to put a spacer under the spring, or get the "Complete height adjustable coil-over kit".
Old Sep 8, 2010 | 10:09 PM
UnVmySS's Avatar
where can I get that? Another guy recommended using washers to space it. Is that safe?
Old Sep 9, 2010 | 12:27 PM
Z28SORR's Avatar
If you mean the Coil-overs? Stranos and others. If you mean spring spacers, do a google search under "spring spacers".
Old Sep 9, 2010 | 04:08 PM
Brangeta's Avatar
Yeah, put a person in the driver's seat and then remeasure. You're supposed to have a person in the driver's seat when aiming your headlights as well!
Old Sep 9, 2010 | 07:54 PM
Rebelphotog96's Avatar
Did you check the spring isolaters? Did you make sure the springs are all installed correctly? (as in, are they all turned the right way?)
one wicked element
Sep 10, 2002 09:09 AM
Alan566
3rd Gen / L98 Engine Tech
Aug 19, 2002 05:52 PM
Alan566
Aug 18, 2002 02:05 PM
one wicked element
Aug 16, 2002 10:56 PM
one wicked element
Jul 6, 2002 09:07 AM
