how to replace a broken window
Old Apr 25, 2008 | 05:17 PM
Garcia95's Avatar
hey guys someone broke in to my girlfriends car last night an a window was broken and i was wondering if its a big deal to put in a new window its a 99 nissan altima
we alrady bought a window but is it difficult to replace
Old Apr 25, 2008 | 09:56 PM
lt1 beast's Avatar
if the window has tabs that are glued on then you will want to take note of where they sit on the window because this is critical for correct movement without binding. On a window that is bolted on you only need to worry about sliding the window down the track (grease the track while your in there)to get the window in you will need to angle it a little then you should be able to set it straight. Also make sure you vacuum all the glass out of the door and in between the seats. you should also turn the ac vents on high to makes sure she wont get any glass shards blown into her eyes.
Old Apr 27, 2008 | 04:37 PM
Garcia95's Avatar
thanks man the windows were bolted
Old Apr 27, 2008 | 08:40 PM
lt1 beast's Avatar
no problem how does the window work? was there any glass in the vents?
Keenan
Jan 19, 2023 12:24 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
Jazsun
Dec 29, 2014 12:14 PM
x7x7
Aug 15, 2002 06:49 PM
