how to replace a broken window
hey guys someone broke in to my girlfriends car last night an a window was broken and i was wondering if its a big deal to put in a new window its a 99 nissan altima
we alrady bought a window but is it difficult to replace
if the window has tabs that are glued on then you will want to take note of where they sit on the window because this is critical for correct movement without binding. On a window that is bolted on you only need to worry about sliding the window down the track (grease the track while your in there)to get the window in you will need to angle it a little then you should be able to set it straight. Also make sure you vacuum all the glass out of the door and in between the seats. you should also turn the ac vents on high to makes sure she wont get any glass shards blown into her eyes.
