help me pick 3 out of the 7 gauges
Old Jan 29, 2008 | 01:17 AM
bighash007's Avatar
help me choose 3 out of the 7 gauges
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
Old Jan 29, 2008 | 08:17 AM
You've already got oil pressure, water temp and voltage on your dash panel - no need to duplicate them. If you don't have a supercharger or a turbo, you don't need a boost gauge. That leaves you with only 3 real choices:
-A/F ratio (will do little more than provide a psychedelic light show as the A/F ratio cycles back and forth rapidly in closed loop - no useful info)
-Vacuum
-Oil Temp
None of those seems particularly useful.
Old Jan 29, 2008 | 08:20 AM
RS96Silver's Avatar
the stock oil pressure gauge i will never rely on....get a mechanical one....a/f is a light show really like fred said and u could get a boost/vacuum gauge if u wanna watch a needle bounce back and forth
Old Jan 29, 2008 | 06:15 PM
bighash007's Avatar
aight thanks guys
Old Jan 29, 2008 | 06:39 PM
2000GTP's Avatar
I just wouldn't throw gauges on there to have them. Its not on the list, but a gauge that might be of some benefit to you would be a tranny temp gauge.
Old Jan 29, 2008 | 06:44 PM
bighash007's Avatar
interisting, any other suggestions that might be useful off top of your head?
Old Jan 31, 2008 | 10:36 AM
Evolution223's Avatar
I've got the same package with trans temp, A/F & the Vaccum.
I did the install no my 3.8 , here's how
1. vaccum, just drill a hole into your intake and tap with 1/8 npt tap, get the connector from autozone to connect to the gauge hose.
2.a/f - this was a pain because there are 5 blue wires running to the ecu, I had to cut & splice every single wire before I found the right one.
3. trans-temp, make sure you get the correct adapter for the sensor, it is a 1/8" npt thread. You might have a hard time finding it as only speacilty shop can order it. Then it must be welded to the pan. Or it is posible that the drill & screw on drain plugs from autozone have the 1/8 not thread but I haven't checked.
I bought a 2nd oil pan just so I could have it welded while still driving the car. I actually screwed up the first pan because I had the wrong size adapter and it leaked so I had to do it again.
Be very careful when choosing the spot for the temp sensor, it is very tight under that auto trans oil pan, I have mine on the front right corner.
Old Jan 31, 2008 | 11:22 AM
1. vaccum, just drill a hole into your intake and tap with 1/8 npt tap, get the connector from autozone to connect to the gauge hose.....
Is there no existing full-vacuum port on a V6 intake that you could "tee" into with a plastic fitting? Doesn't it have the vacuum connection for the HVAC system, for example, that you could have used?
Old Jan 31, 2008 | 02:25 PM
yes there is,, but it's on the back of the engine way under the windsheild, near impossible to get to, plus I couldn't figure out how to get i t apart. it's eaiser just to drill & tap up front into the intake manifold, plus you don't have to worry about screwing up any of the factory workings.
ofcourse i used a shop vac to try to avoid getting chips in the intake manifold.
dylan1303
May 22, 2015 12:24 PM
Nickster 7
May 1, 2015 09:04 PM
4586
Apr 29, 2015 01:43 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
