Removing window tint
Old Jan 17, 2008 | 09:53 PM
convertz's Avatar
My girlfriend just failed inspection for tinted windows, and decided to take it off.
I have been doing some research and have found a few methods.
-Ammonia and water, covered in a garbage bag sitting in the sun, then just peel
-Steamer then peel
-Hairdrier and peel
-Just peel
All followed up with a razor blade or some steel wool and some kinda thinner
Anybody have a way that worked well? Im leaning toward the steamer, seems the idea is to get the glue melted and soften the film so they come off together and dont break.
thanks guys
Old Jan 17, 2008 | 09:56 PM
sc1twntrbo's Avatar
side window or rear window with defrost?
JP94Z's Avatar
I too am very interested in any insight someone can offer on this. Side windows are easy, but man is my back window being a pain!!
Old Jan 17, 2008 | 09:57 PM
J96Z's Avatar
Just peel it off and wash the residue off with a acetone soaked rag.
Old Jan 17, 2008 | 10:02 PM
sc1twntrbo's Avatar
well i use simple green to break the glue. simple green and a plastic choir boy on the back window and simple green and razor on the sides. but ive learned its worth the $100 to pay a tint guy to take it off
Old Jan 17, 2008 | 10:19 PM
convertz's Avatar
Just the front 2 windows
its a lancer so it doesnt have gigantic F-body side windows
Old Jan 17, 2008 | 10:35 PM
J96Z's Avatar
took me all of maybe a half hour the way I described above
Old Jan 24, 2008 | 11:41 AM
dalynchmob's Avatar
The amonia method worked great on my back window.
Old Jan 30, 2008 | 02:26 PM
mcalus's Avatar
How old is the tint? I have had to take tint off my old camaro tons of times cause I kept putting it back on ... If it is not totally faded and still in good condition then just pick at one of the corners and slowly peel it off. If you peel slow enough you might get lucky and not have to clean the glue off. If the glue is on the window just use some steel wool (home depot) and some glass cleaner. If it is older tint then use a heat gun you will see it pull away from the glass and it should be pretty easy...hope that helps keep us updated.
Old Jan 30, 2008 | 08:46 PM
dilligaf241's Avatar
i removed the old tint in my camaro, if it's just the side windows here is all you need to do.
peel the old tint off by starting on a corner with a razor to lift it up. then blue windex and the razor to remove the left on glue. i used the windex because i didn't wanna deal with acetone or ammonia and it worked fine. back window and it has the defroster lines then you would need to bag it or use steam/heat. don't try to dry peel the back or the defroster will be shot.
Old Jan 31, 2008 | 07:00 PM
javi805's Avatar
I took mine off early in the morning when the windows are damp its easier that way then use paint remover to take off the glue thingy...seems to come off hella fast
DirtyDaveW
Dec 1, 2016 05:37 PM
ShwaZedder
Apr 9, 2015 06:33 AM
warmeck
Jan 20, 2015 10:29 PM
Collector Car
Jan 5, 2015 10:58 AM
CaRParts102
Dec 6, 2014 08:45 AM
