Fender Alignment
Old Aug 9, 2002 | 05:18 AM
Central PA Z's Avatar
Post Fender Alignment
Put a new aftermarket hood on the Z this week and there seems to be more gap between the sides of the hood and the fender. More so than the stock hood. Is there any way to adjust the fender as to push it in closer to the hood??
~John
1994 Z Car
www.slfba.com
The usual stuff on a set of Nittos and a dead posi.
60' = 1.920
1/8 = 8.368 @ 83.88
1/4 = 12.968 @ 108.04
Old Aug 9, 2002 | 07:32 AM
v7guy's Avatar
Post
To pull it in you'll need to shim the fenders, you can do it one of two ways.
You can get washers of various thicknesses to put between the fender and the body, this will pull the fender in to the desired amount, or you can use real shims(looks like C-clips), they make it a little easier because you don't have to take the bolt out to install them, just lossen it.
You could also go ghetto and stick a piece of plastic inbetween the fender and the body to pull it out, but it doesn't look as good.
Old Aug 9, 2002 | 04:27 PM
Post
Ok, thanks nov194. I'll give it a shot tomorrow and see what happens.
~John
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
Boss002
Jul 24, 2015 10:47 AM
240ssLs3
Jul 13, 2015 05:06 PM
ducttape1975
Jul 10, 2015 06:29 PM
