Help with the REversed INdiglo Gauge!!!!
Old Aug 8, 2002 | 08:45 PM
MAXXXX's Avatar
Question Help with the REversed INdiglo Gauge!!!!
I am new here... just got the reversed gauge from Procarparts.com... looks pretty cool, but is there anyone can tell me how to connect the 2 wires??? One black is ground i assume how about another one the red one???
My car is 95 Pontiac Firebird... the parking light switch should be the same as trans ams... can anyone help me??? Tried Camarov6.com nobody replied. Where do i connect the red wire to?????
THANKS ALOT!!!!!!!
Old Aug 8, 2002 | 09:13 PM
blown383's Avatar
Post
Take off your diver's side air vent cover and remove the two screws that hold the switch to the dash. You want to splice the red wire into the grey wire on the connector in the back of the switch and the black wire into the black wire. This way you will be able to dim the gauges along with the rest of your interior lights, and they come on when you turn on your head lights.
-B
Old Aug 8, 2002 | 09:25 PM
MAXXXX's Avatar
Post
THANKS MAN... BUT MY CAR IS A 95.... PROBABLY IT IS KINDA DIFFERENT... ARE YOU SURE????
THANKS
Old Aug 9, 2002 | 06:54 PM
AW/whiteZ-28's Avatar
Cool
I have a 95 just look in the fuse panel on the driver side and there WILL be a gauges spot look on the picture on the panel and match it up to the fuse box and wire into that, the dimmer WILL work with it I have my neons wired into the guages so I know it will work
[This message has been edited by AW/whiteZ-28 (edited August 09, 2002).]
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
