clear corner problem
Old Jan 23, 2004 | 07:15 AM
JASON5's Avatar
i have some of the euro clear corners and they keep getting moisture in them and it builds up, is there anyway to fix this problem thanks
Old Jan 23, 2004 | 08:40 AM
Jilly's Avatar
Get rid of them.
BTW, try the Appearance Section.
Old Jan 23, 2004 | 08:52 AM
PhantomTA's Avatar
Moderator
Originally posted by Jilly
Get rid of them.
Wanna be a mod Jill?
Old Jan 23, 2004 | 09:30 AM
AxeGrinder30thZ's Avatar
I don't know what to tell you. I have clear corners and they never get moisture or anything in them.
Old Jan 23, 2004 | 09:49 AM
Jilly's Avatar
Yeah. You're slacking on the job so I gotta take over.
Old Jan 23, 2004 | 12:08 PM
ppmz28's Avatar
The only thing i can think of is that somewhere they aren't sealed good, or a crack in them in the back or front. Did you put the rubber seal in with the light bulbs?
Old Jan 23, 2004 | 04:16 PM
joSShua's Avatar
That happened to mine when I first put my clear corners in. Its just a bad seal. Make sure the bulb harness is seated and snuggly fitted into the hole. Rubbers gaskets also must be used.
Old Jan 24, 2004 | 02:28 PM
bigde4u's Avatar
Get rid of them.
tisk, tisk always sooo negative.
I have some and they don't get moisture in them. Check the around the bulb and you could even put a seal around the joints in the light.
Old Jan 24, 2004 | 08:14 PM
Jilly's Avatar
Not always. Just most of the time.
Old Jan 24, 2004 | 08:30 PM
bigde4u's Avatar
brandboZ28
Jan 31, 2003 06:19 PM
silver97Z
Sep 11, 2002 03:17 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
Absolute Z28
Jul 19, 2002 02:21 PM
