clear corner problem
i have some of the euro clear corners and they keep getting moisture in them and it builds up, is there anyway to fix this problem thanks
Get rid of them.
BTW, try the Appearance Section. |
Originally posted by Jilly Get rid of them. BTW, try the Appearance Section. |
I don't know what to tell you. I have clear corners and they never get moisture or anything in them. :confused:
Originally posted by PhantomTA Wanna be a mod Jill? :) |
The only thing i can think of is that somewhere they aren't sealed good, or a crack in them in the back or front. Did you put the rubber seal in with the light bulbs?
That happened to mine when I first put my clear corners in. Its just a bad seal. Make sure the bulb harness is seated and snuggly fitted into the hole. Rubbers gaskets also must be used. :usa:
Get rid of them. I have some and they don't get moisture in them. Check the around the bulb and you could even put a seal around the joints in the light. |
Originally posted by bigde4u tisk, tisk always sooo negative.;) :) |
Originally posted by Jilly Not always. Just most of the time. ;) |
