Clear Corner Moisture Fix! Finally!
Old Apr 13, 2004 | 10:24 PM
onefynryd's Avatar
Thumbs up Clear Corner Moisture Fix! Finally!
Everyone has problems with thier clear corners getting water in them, right? Well I did anyway and I finally stopped the water from getting in my lense and fogging it all up. Cost me only .69 cents
Ok heres the deal, I swaped my oranges out for clears and when I took the harness out of the oranges I noticed that only one of the harnesses socket had a rubber seal around the harness that goes in the turn lights. So when you put the light back in the socket it seals tight. Went to dealership to find a part number for it and like usual they had no idea and told me I had to buy the whole harness , yea ok. So I put the lights in and just let the seal on the one side in there. Washed car twice and I had a fish tank lense. The lense without the seal was full of water already . Took the rubber seal out of harness and headed to Menards. Picked up a o-ring about the same size and headed home to try it out. 2 weeks later, wala no more water in my clear corners
So, It worked for me! Very cheap too so if it doesn't work for you, your not out much, but worth a try.
Here's the o-ring info:
1-5/16 X 1-1/8 X 3/32
#64 O-RING
STK NO 35778B
Cost : A wopping .69 cents a piece!
Hope this helps ya all out
Old Apr 13, 2004 | 11:47 PM
bigdreamZ's Avatar
Good deal, one of my clear corners looks like a fish tank right now. I will have to give that a try.
Old Apr 14, 2004 | 08:09 AM
MustangEater82's Avatar
Would be kinda cool if you coudl put fish in them, woudln't it?
but thanks for the headsup I still haven't gotten around to insalling mine.
Old Apr 14, 2004 | 12:24 PM
AW/whiteZ-28's Avatar
You shoulda did a search we solved that awhile ago
but we didn't have a part number, good job!
Old Apr 14, 2004 | 01:09 PM
Camaro_Guru16NY's Avatar
You could also just resillicone the exterior seal on them as well, thats what we did here a few months ago.
-john
Old Apr 14, 2004 | 10:42 PM
stangkilla1's Avatar
Very good solution, why did'nt I think of that?
Old Apr 15, 2004 | 12:38 PM
JSK333's Avatar
What brand do you guys use that leak?
I have had APCs for about 2 years and they have yet to leak.
silver97Z
Sep 11, 2002 03:17 PM
formula383
Sep 7, 2002 12:17 AM
Penthos
Sep 6, 2002 09:34 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
