Asf Wheels
Old Jul 25, 2003 | 12:33 PM
blackz151's Avatar
Asf Wheels
i got my z06 rims 2 day sick sick rims love them any way i just put the rims on the car to see how it would look cuz tires dont come in till tuesday. Has any one had a problem wit the 18X9.5 wit 275-35-19 rubbing. I mean its not rubbin now but its close and i just dont wanna have a problem when i put tires on it.
nick
ps. ASF IF THE SH*T
Old Jul 25, 2003 | 12:58 PM
SuperDave479's Avatar
Re: Asf Wheels
nick
ps. ASF IF THE SH*T
Why do you have a 18" wheel but 19" tire?
Old Jul 25, 2003 | 01:09 PM
blackz151's Avatar
sry typo its 275-35-18
Old Jul 25, 2003 | 01:26 PM
Ok. Well this probably won't help much but I have Y2k C5 wheels that are 17X9.5" on 275/40/17s all around and I don't have any problems at all.
Old Jul 25, 2003 | 08:36 PM
blkls1z28's Avatar
No problems at all. I have had them for over a year and they haven't rubbed once.
Old Jul 25, 2003 | 09:50 PM
AlcoHall's Avatar
Are the corvette and f-body wheel offset the same?
Old Jul 26, 2003 | 08:54 AM
iamsparc's Avatar
Offset....you can check here.
Old Jul 26, 2003 | 11:31 AM
The 18x9.5" Z06 repro wheels supposedly have an offset of 61mm, according to VETTE magazine. Did AFS quote you an offset or a backspace?
A 61mm offset on a 9.5" (bead) wide wheel, gives you roughly a 7.62" backspace. That should not rub, but will be close. The 17x11 50mm offset AFS ZR1 wheels have a 7.93" backspace, and they are almost certain to rub, but with 0.31" extra clearance, you should be OK.
[EDIT] The above comment on 7.62" BS vs. 7.93" BS applies to the back wheels. In the front, it may be tighter. My front 56mm offset 17x9.5" AFS ZR1 replicas have a BS of 7.42", and that puts them very close to the steering knuckle. With an 18" wheel, you gain a little extra BS, because the knuckle curves away from the rim, the higher you go on the knuckle. Check it very carefully when you put the wheel/tire on.
Some C5 wheel data:
Z06:
18x10.5 GM & repro - 58mm
18x9.5 repro - 61mm
17x9.5 GM & repro - 54mm
17x8.5 repro - 56mm
2001/2002:
18x9.5 GM & repro - 65mm
17x8.5 GM - 58mm
17x8.5 repro - 56mm
2000:
18x10.5 repro - 58mm
17x9.5 repro - 56mm
17x8.5 repro - 56mm
17x8.5 GM - 58mm
1997-1999:
18x9.5 GM & repro - 61mm
17x8.5 GM & repro - 56mm
Stock F-Body wheels:
16x8 - 55mm
17x9 - 55mm
You can't just look at the "offset" to see if they will rub. It is the backspace that determines that. Backspace can be calculated (roughly) from offset and rim width:
(bead width/2) + (offset/25.4) + (bead retainer flange)
The typical bead retainer flange, or "edge" of the wheel is in the range of 0.45" - 0.50"
Example for a 9.5" wheel with 61mm offset:
(9.5 / 2) + (61 / 25.4) + 0.47 =
4.75 + 2.40 + 0.47 = 7.62" backspace
Old Jul 26, 2003 | 11:50 AM
iamsparc's Avatar
OUCH! My head hurts!
Old Jul 26, 2003 | 01:22 PM
miller6t9's Avatar
i put the AFS chrome Z06 wheels on my 01 SS last week and have had no problems, got a set of perilli p 7000 275/35/18 and have no prob whatsoever. I think the offset on these wheels was 56 mm
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
