Asf Wheels
Asf Wheels
i got my z06 rims 2 day sick sick rims love them any way i just put the rims on the car to see how it would look cuz tires dont come in till tuesday. Has any one had a problem wit the 18X9.5 wit 275-35-19 rubbing. I mean its not rubbin now but its close and i just dont wanna have a problem when i put tires on it.
nick
ps. ASF IF THE SH*T
nick
ps. ASF IF THE SH*T
Re: Asf Wheels
nick
ps. ASF IF THE SH*T
nick
ps. ASF IF THE SH*T
sry typo its 275-35-18
The 18x9.5" Z06 repro wheels supposedly have an offset of 61mm, according to VETTE magazine. Did AFS quote you an offset or a backspace?
A 61mm offset on a 9.5" (bead) wide wheel, gives you roughly a 7.62" backspace. That should not rub, but will be close. The 17x11 50mm offset AFS ZR1 wheels have a 7.93" backspace, and they are almost certain to rub, but with 0.31" extra clearance, you should be OK.
[EDIT] The above comment on 7.62" BS vs. 7.93" BS applies to the back wheels. In the front, it may be tighter. My front 56mm offset 17x9.5" AFS ZR1 replicas have a BS of 7.42", and that puts them very close to the steering knuckle. With an 18" wheel, you gain a little extra BS, because the knuckle curves away from the rim, the higher you go on the knuckle. Check it very carefully when you put the wheel/tire on.
Some C5 wheel data:
Z06:
18x10.5 GM & repro - 58mm
18x9.5 repro - 61mm
17x9.5 GM & repro - 54mm
17x8.5 repro - 56mm
2001/2002:
18x9.5 GM & repro - 65mm
17x8.5 GM - 58mm
17x8.5 repro - 56mm
2000:
18x10.5 repro - 58mm
17x9.5 repro - 56mm
17x8.5 repro - 56mm
17x8.5 GM - 58mm
1997-1999:
18x9.5 GM & repro - 61mm
17x8.5 GM & repro - 56mm
Stock F-Body wheels:
16x8 - 55mm
17x9 - 55mm
You can't just look at the "offset" to see if they will rub. It is the backspace that determines that. Backspace can be calculated (roughly) from offset and rim width:
(bead width/2) + (offset/25.4) + (bead retainer flange)
The typical bead retainer flange, or "edge" of the wheel is in the range of 0.45" - 0.50"
Example for a 9.5" wheel with 61mm offset:
(9.5 / 2) + (61 / 25.4) + 0.47 =
4.75 + 2.40 + 0.47 = 7.62" backspace
Some C5 wheel data:
Z06:
18x9.5 repro - 61mm
17x8.5 repro - 56mm
2001/2002:
17x8.5 GM - 58mm
17x8.5 repro - 56mm
2000:
17x9.5 repro - 56mm
17x8.5 repro - 56mm
17x8.5 GM - 58mm
1997-1999:
16x8 - 55mm
17x9 - 55mm
30th Anniv Z28
Aug 1, 2015 10:39 AM
jasonduaine
Jun 4, 2015 09:29 AM
