93-96 to 97+ Dash conversion
Old Jun 29, 2006 | 03:31 PM
  #16
96speed's Avatar
Re: 93-96 to 97+ Dash conversion
Originally Posted by Z95m6
To you guys that have actually done this swap i have a question. In that on line "guide" with the wiring diagram it says this
"You will also need to ground a wire from the ASR slot (A8) if you do not have traction control in order to keep it from staying lit"
Does that just mean i put a pin into the hole and run it straight to a ground? Thats what it sounds like but i don't want to burn anything up. I don't have Traction control. Thanks guys.
Yup.
I made that online guide. I'm selling the dash/cluster/ac ducting if anyone wants it for themselves.
Ryan
Old Jun 29, 2006 | 04:34 PM
  #17
Blue96z28's Avatar
One question on the swap while your here: do the panels below the dash(ones with the hood release) need to be swapped in from the 97+ car when going from 93-96 ----> 97++ or are they the same?
thanks
Old Jun 29, 2006 | 06:52 PM
  #18
TheBlur's Avatar
How long ago did I make this thread ?
I don't remember making it recently unless I was drunk ?
Old Jun 29, 2006 | 07:36 PM
  #19
Honda Hunter's Avatar
Drunk 2 years ago.
Old Jun 29, 2006 | 07:48 PM
  #20
Z95m6's Avatar
just a note, i did this swap with a TA dash which is wired the same as a 97+ camaro dash and i didn't have to ground any wire to keep the seatbelt light from being on constantly.
Old Jun 29, 2006 | 08:16 PM
  #21
Blue96z28's Avatar
cool, did you have to change your lower panels though? ^^description from my last post.....above.
Old Jun 29, 2006 | 08:50 PM
  #22
If I wanted a complete 97 dash and digi speedo what partnumbers would I need?
Old Jun 29, 2006 | 09:56 PM
  #23
96speed's Avatar
thanks
No, they do not need to be changed. They might be different, but my stockers worked fine .
HondaHunter - Are you considering buying averything new from GM? You could probably buy a complete running car for that figure . Check out the link. It has just about everything you need to know.
Ryan
Old Jun 29, 2006 | 10:13 PM
  #24
I have no way of getting the parts local. I wish I could find the complete setup used somewhere.
Old Jun 30, 2006 | 01:14 AM
  #25
94Z28WP's Avatar
Watch ebay.. I'm always seeing a 97+ dash for sale... A 97 Z28 cluster is hard to find though... My interior looks tons better with the 2000 Z28 dash.
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
