18/ 9.5 rims
Old Feb 22, 2003 | 12:25 AM
ATI - T/A's Avatar
18/ 9.5 rims
can you fit a 315 on a 9.5 rim or does it have to be 18/11?,aslo can u fit a 18 inch rim in the rear of are cars with a 315 thanks
Old Feb 22, 2003 | 12:51 AM
sleeperZragtop's Avatar
Perry, I've seen it done before...it will bulge a bit but not much..there was a T/A in the GMHTP mag that had 315's on a 9.5 rim...no big deal....you'll be fine..are you gonna have E/T's on your car when you drag? BTW...go with a softer tire so it will be easier to mount...Houman can mount them for you at his uncle's shop...pm him for info...take care buddy...Mike
Old Feb 22, 2003 | 10:58 AM
As the wheel diameter goes up, and the sidewall aspect ratio goes down, fitting the correct tire to the correct rim width becomes more critical. While a 315/35-17 requires an 10.5-12.5" wide rim, a 315/30-18 has tighter limits at 10.5-11.5" (Michelin) or 11.0-12.0 (Pirelli). There just isn't as much sidewall to "bulge"... it will be stressed.
Putting a 315/35-17 on a 9.5" rim looks bad, IMHO, gives a poor contact patch due to scrunching the tire on too narrow a rim, and reduces tire life with excessive flexing and temperature buildup. Put a 315/30-18 on a 9.5" rim, and you are asking for trouble.
Go to Tire Rack, look up the specific tire manufacturer, size and tire model you plan to use, and look for the manufacturer's recommended wheel widths. I'd suggest you follow those recommendations, within maybe a 1/2" tolerance.... but that just my opinion...... .
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
