neon lighting
Old Feb 20, 2003 | 11:19 PM
PentaVolvo's Avatar
neon lighting
Those of you that have neon interior lighting, what length are they and where specifically did u put them
Old Feb 20, 2003 | 11:32 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
i have 2 12" blacklights . one is above the drivers legs under the dash, and one is over the passengers legs mounted under the dash also
Old Feb 20, 2003 | 11:58 PM
jeff94z28's Avatar
2 red neons 9 inch. 1 above my feet 1 above passangers feet. Have 1 red 9 inch left but I dont know where to put it?
Old Feb 21, 2003 | 01:41 AM
95Zdroptop's Avatar
My girlfriend had to take those blue windshield washer lights off her truck so I put them under my dash. Damn those little suckers are bright. Proably not as bright as a 10 inch tube but it does the trick. Also hides well and is less likely to get kicked
Old Feb 21, 2003 | 12:29 PM
MeefZ28's Avatar
2 license plate neons under the seats. Lights up the front and back floorboards- it looks sweet meef. I highly recommend it.
Jeff- I'd put the other one in the trunk against the back side, shining toward the front of the car. I'd mount it to where you couldnt see it in the rearview, but it lit up the trunk and the hatch area. then you could open your trunk and it'd be lit up w/out seeing the bulb- I'm all for the subtle glow rather than "hey look at this neon i mounted on the roof by my dome light or rearview mirror!"
lata,
J
Old Feb 21, 2003 | 12:33 PM
jeff94z28's Avatar
Yea I want it to be hidden too. I use to have them in the back speaker grills and 1 above my feet but the grills you could kind of see the bulb. It made the grills glow from certain angles but from others you could see the bulb. I really dont want it to be seen from any angle. In the trunk is cool til someone walks past the car. I think Im just gonna leave it around til a bulb busts.
Old Feb 21, 2003 | 04:06 PM
joed4640's Avatar
i have 2 15 inch under passenger/driver dash
2 15 inch inbetweendoor and seat
2 9 inch under seats(for the rear seats)
3 2 inch for the vents
all wired to swiches through that opening in front of the shifter
i need to make a mounting bracket for them
Old Feb 21, 2003 | 06:13 PM
PentaVolvo's Avatar
Do you guys thing if i put em like 2 10" under driver and passenger sears it would provide sufficient for both front and rear. Or should I put 2 under dash and then 2 under seats
Old Feb 22, 2003 | 10:54 AM
stik6shift00's Avatar
i want to hide mine, i dont know what size i have but its hard to fit it under the driver side dash, do you just go right above the pedals?? cause i know i would smash that in so bad if i did, i like that LED snak eyes idea, (windshield washers) cause i dont want it to stand out too much.
Old Feb 22, 2003 | 11:24 AM
MeefZ28's Avatar
I don't think one 10 on each side would work. But a license plate would. Check out the pic on page 2 of my "website" icon. It shows mine.
-Jay
DirtyDaveW
Mar 15, 2015 07:01 PM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
XtremeLt1
Sep 13, 2002 08:50 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
