Whats stronger, SBC 400 steel crank turned down or Scat 383 cast crank
Old Aug 27, 2002 | 07:37 AM
LTOne4Fun's Avatar
Post Whats stronger, SBC 400 steel crank turned down or Scat 383 cast crank
What would hold up under moderate nitrous use and rpm (150-200 shot and 6700 rpm) Ha anyone had one break on them
Old Aug 27, 2002 | 09:19 AM
drop top steve's Avatar
Post
I would never use a oem 400 crank in a 350 block, it's just too weak. The scat?? couldn't tell ya, I think you would be close to it's limit with a 200 shot at 6700.
Old Aug 27, 2002 | 09:22 AM
BlackHawk T/A's Avatar
Post
You need a Callies Crankshaft:
www.callies.com
Old Aug 27, 2002 | 11:45 AM
Lowend's Avatar
Post
We have used Scat cranks in some pretty brutal applications without problems.
I don't think anyone here will argue that the turned down 400 crank is stronger.
Another plus of using a Scat, Cat or Cola crank is that you can order them for internal balance.
1971 Camaro
12" brakes
16x10" wheels
VSE swaybars
350 / M21
Autocross Competitive
'83 FSP GTI (driver)
Administrator; 2nd Generaton Camaro Owners Group (2GCOG)
www.nastyz28.com/2gcog/2gcog.html
Sales / Tech
"The Speed Merchant" - San Jose, CA
Old Aug 27, 2002 | 04:05 PM
LT1 1980 malibu's Avatar
Post
I wouldnt say that the 400 crank is weak...Afterall it is nodular iron..But think about it..Most are already beat from years of useage and by the time the thing is turned and balanced youll spend more..
Nothing wrong with a scat peice but since your thinking cast you probally bugeted low..Save up for teh ceaper forged cranks avail..If you shop around well you can source one up for about $450..
FLUCK A SPELL CHECK<I CAN SPELL REALLY GOOD< IT'S JUST THE TYPEING THAT STINK AT!
http://phillyfabanddesign.tripod.com/parts4sale/
http://phillyfabanddesign.tripod.com/phillyfabricationanddesign/
http://phillyfabanddesign.tripod.com/PhillyFabsLT1RX7/id1.html
88 RX7 GTU, 97 Lt1/700R4,10" 3K stall, 4.30 gears,285CFM heads,12.4-1 compression, custom cam and 2700lbs...Daily driven!
Old Aug 27, 2002 | 04:25 PM
LTOne4Fun's Avatar
Post
I have a internally balnced (with Mallory) crank thats been 10.20s in a LT1... It held up to thatbut should I be worried?
Chevyguy358
Jan 28, 2015 08:04 PM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
formula79
26
Aug 5, 2002 12:21 PM
