Whats this I hear about aftermarket oil pumps sucking?
Old Jan 14, 2003 | 11:05 PM
LTOne4Fun's Avatar
Seen a couple of posts about them sucking the pan dry and other horror stories killing new motors. Hows this so? High pressure or high volume versions?
Everyone seems to be recommending a stock pump with a GMPP white springs. Why that over a high pressure pump (IM guessing its the high volume that sucks them dry)
Old Jan 15, 2003 | 01:37 AM
89ProchargedROC's Avatar
Re: Whats this I hear about aftermarket oil pumps sucking?
if you use a high volume pump with a stock capacity pan it *can* possibly pump too much oil up to the valvetrain and not keep enough oil in the sump for the bottom end. The solution is to buy a pan with more quart capacity. I had to do this
Old Jan 15, 2003 | 07:22 AM
Some confusion in your post. If you add a higher pressure spring to a stock pump, you have in effect created a "high pressure pump". A high pressure pump is not a high volume pump. They are two different things. The only way you can increase the volume pumped at any given RPM is to increase the body size of the pump.
Old Jan 15, 2003 | 08:14 AM
LTOne4Fun's Avatar
I understadn that, but peopel werent specific when they said "my melling pump caused my motor to blow up, Id say get a stocker with whitesprings". Now, i will be running a stock pan, I could prolly weld in soem baffling, but assuming i dont, would a Melling Hihg Pressure (not volume) be ok wiht it? Is therre any reason why I shoudl choose a stock GM with white springs over one of those?
Old Jan 15, 2003 | 07:24 PM
Some of the wildest 1/4-mile LT1's that I'm familiar with use(d) the stock pan with windage tray, and stock pump with a high pressure spring, including George Baxter's 1,125HP monster....... That combo has also worked for me, although I'm a little shy on the HP department, making about 30% less that he had.......
I figure if it works and its cheap, why change it.....
Old Jan 15, 2003 | 08:42 PM
Cammin1's Avatar
I"m spectical too, I think most of these stories came from being a quart or 2 low to begain with.
Old Jan 15, 2003 | 09:30 PM
LTOne4Fun's Avatar
do lt1 comes with a windage tray? if not what oen are you all using
Old Jan 15, 2003 | 10:31 PM
96z's Avatar
96z
LT1's do come with a windage tray....atleast my 96 did. Its just a flat piece of metal. SStrokerAce and I have been thinking about an aftermarket one for my motor so Ill be interested to see if people like them or not...
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
