What happened to the Plastic LT1 intake idea?
Old Jan 24, 2005 | 11:01 PM
  #16
Gripenfelter's Avatar
Re: What happened to the Plastic LT1 intake idea?
DesiZ28@hotmail.com
I'll host them!
Bersaglieri: No heat soak, better design with longer runners and more cfm.
Old Jan 24, 2005 | 11:24 PM
  #17
Camaro_Guru16NY's Avatar
Originally Posted by SStrokerAce
I've got some pictures of it if someone wants to host them.
Bret
Bret I can host them as well if needed.
later,
-john
Old Jan 25, 2005 | 01:23 AM
  #18
SStrokerAce's Avatar
I just have one pic in my files from PRI...
it's of the inside of the pleanum and it's pretty cool looking since you can cast the intake like this from the start....
Bret
Old Jan 25, 2005 | 08:22 AM
  #19
So where are the pics guys?
Old Jan 26, 2005 | 09:27 AM
  #20
PurePonyPounder's Avatar
There a was a thread on this topic roughly two years ago and the summarization of it all was that material and the equipment involved were too costly for it to be a profitable aftermarket part.
Johnny
Old Jan 26, 2005 | 09:46 AM
  #21
Chris'SS #2152's Avatar
It's if it's a sema show part then it's probably most likley a 1 off part and cost $$$ money to produce.
I would like to see one made though...save me time and effort on a alum. intake.
Old Jan 26, 2005 | 11:28 AM
  #22
I checked with a plastic injection company in Alberta just for giggles.
$20,000+ for the prototype, molds, etc. Unless you sell 100,000 units its not worth it.
I hope FAST produces one.
Old Jan 26, 2005 | 11:33 AM
  #23
Here is a low volume company:
http://www.lltoolinj.com/
Old Jan 26, 2005 | 01:26 PM
  #24
StickMaster's Avatar
What type of plastic? That wont melt or warp from heat?
Old Jan 26, 2005 | 01:55 PM
  #25
kcshaner's Avatar
Do you think a plastic intake could handle a lot of power/boost without cracking?
Old Jan 26, 2005 | 02:05 PM
  #26
stik6shift93's Avatar
The lsX intakes are plastic(actually composite i believe) and don't have problems with boost. It seems the major factor holding this up is the price of the intial molding startup. Has anyone ever tried taking a block of plastic and cncing it out? It seems like you could do it on our intake if you did it in two seperate pieces, one with the main body and one with the front portion where the throttle body mounts to which could be plastic welded on to the body after all the internal cncing was done.
Old Jan 26, 2005 | 03:28 PM
  #27
Not a bad idea.
Old Jan 27, 2005 | 01:03 AM
  #28
I just thought about this the other day, would it be feasible to melt a couple of LS1 intakes and basically pour it into a LT1 intake mold. Anyone out there know the temp at which those thermal plastic intake melt? I know theres more to the entire process but just to get it off the ground.
Johnny
Old Jan 27, 2005 | 01:55 AM
  #29
It would be easier to make a fiber glass intake. If you want to do low volume that is.
Bret
Old Jan 27, 2005 | 08:51 AM
  #30
got_hp?'s Avatar
Bret
exactly!
just take a large block of foam and a foam-shear and carve a mold, then fiberglass it. the materials would not be expensive at all, but you would have to make it a two-piece design so the mold could be reused. the bottom half being the runners and lower half of plenum, and the top basically just being the cap of the plenum. then you could slide the mold out and re-use it.
once the mold is out you could fiberglass the two pieces together, or epoxy it or something.
