Valvespring question
Old Mar 29, 2007 | 03:47 PM
  #16
mdacton's Avatar
wouldn't running .618 lift on a 918 kill the spring prematurly??
Old Mar 29, 2007 | 08:33 PM
  #17
SStrokerAce's Avatar
MAYBE, but for the most part no. Depends on how you set them up and the lobes you run, plus there are some better beehives with some extra TLC from the manufacture that can do .650" lift all day long without problems.
Bret
Old Mar 29, 2007 | 08:39 PM
  #18
mdacton's Avatar
I meant from the lift being over .600 and the spring says max lift is .600
So if you set them up similar(shimmed more) that would get you less lift correct..and more pres. would this wear the spring out quicker?
Bret my reason for asking is....I had some spare stuff so i'm trying something out,
Old Mar 30, 2007 | 01:46 AM
  #19
Spring wear can be a few things.... one is spring surge, you can control that by setting the bind clearance at the right places, usually tighter controls the surge much much better.
If a 918 binds at 1.140" and is recomended to be installed at 1.800" then they are saying you need .060" to bind.... I don't put them there but I also check my bind and setup the springs at the installed pressure and height that I need. That can easily get you LOTS of miles out of a set of them.
Bret
Old Apr 2, 2007 | 05:48 AM
  #20
cehan's Avatar
What's the best way to check for coil bind on the beehive springs? With the valve at max lift, the beehives don't compress uniformly, the coils sort of stack up from the bottom and the ones that aren't touching all have different clearances between them.
When I did mine, the only thing I could think of was to make up a solid roller lifter, adjust the rocker to zero lash, turn the engine over to put the cam at max lift, rig a dial indicator to the retainer and then crank down on the polylock until the coils bound up. It's been a while, but as I remember I was getting in the 0.050" - 0.060" range.
I guess that was OK; I have about 2000 miles on the engine since, with no problems so far.
Old Apr 8, 2007 | 08:31 PM
  #21
I take them off and put them in a vice and compress them as far as they go. Measure that distance with a caliper and there is your coil bind.
Now a LOT of people will tell you that running a spring to coil bind is bad, but that's not the case. Ask the spring manufactures who make the springs, most of them are compressed to bind during the making of the spring to check them so it's not big deal at all.
As for the distance between the coils, if there is any on a single spring like a beehive you have clearance. One of the advantages of them is that the lower coils stack earlier and aren't considered part of the valve mass then. .050-.060" to coil bind is perfectly fine.
Bret
Old Apr 9, 2007 | 09:10 AM
  #22
AdioSS's Avatar
West South Central Moderator
Just be careful doing this. There is a LOT of stored energy in a fully compressed valvespring! If you use the same clamp to do this a bunch, then it might not be a bad idea to drill a hole through each end of the vice and run a rod through it to keep the valve spring in place in case something does get out of wack.
Old Apr 9, 2007 | 03:54 PM
  #23
Oh yeah, people need to be carefull when compressing a spring like this.
Bret
Old Apr 9, 2007 | 04:10 PM
  #24
blue89rs's Avatar
Is it okay to shim up a spring? Do you just ask for spring shims at the parts store? I have float on my 3.1 motor at 5600 and I supposedly have bigger than stock springs. I'm thinking that shimming up will increase seat pressure.
Old Apr 9, 2007 | 06:25 PM
  #25
Yeah, you need to know the coil bind height, the actual valve lift and add in a clearance into that. Then you can setup the springs at that height.
Bret
Old Apr 9, 2007 | 08:48 PM
  #26
rskrause's Avatar
Moderator
To set up the valve train correctly you need an assortment of shims. Each valve will be a little different and the installed height must be set for each valve separately using the necessary shims. You should get a "shim kit" which typically contains a number of 0.015, 0.030, and 0.060" thick shims.
Rich
HectorM52
Jul 30, 2017 11:46 AM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
RichJ
Sep 26, 2002 09:43 AM
