Vacuum pump kits
Old Oct 29, 2007 | 08:16 PM
  #31
1racerdude's Avatar
Originally Posted by mdacton
This is a race only car I am talking about...mostly brackets and will be raced 2-3 times per week.
Not street driven at all
You will be fine.
Strap it on,set it at about 20" and let it rip.
If ya haven't got the belt and pulleys yet get a Gilmer belt drive. They will make the little pump last longer from not having to be so tight. Plumb it in such a way as to get a small amount of oil to pass through the pump also.
Old Oct 29, 2007 | 08:17 PM
  #32
mdacton's Avatar
Originally Posted by 1racerdude
You will be fine.
I have not ordered any of it yet.
Thanks for the help......how do I get it to pull oil through the pump? something with the regulator?
Old Oct 29, 2007 | 08:22 PM
  #33
1racerdude's Avatar
It's where ya put the suction hoses from the front of each valve covers to the pump. Mount them as low in the front of the covers as you can and only at the front of the covers, not the top.
A mist is all ya need.
Old Oct 29, 2007 | 08:40 PM
  #34
FASTFATBOY's Avatar
Yeh it runs 11.60, come get you some.
You may want to check your informant, he MAY have given you some....uhhhhh...bad info. Come see for yourself, in the other lane.
You can mount the hoses on the top of the cover as long as there is a baffle underneath
David
Old Oct 29, 2007 | 08:42 PM
  #35
FASTFATBOY's Avatar
Originally Posted by 95ttoplt1
Because he can't, as usual he is talking out his azz.
David
Old Oct 29, 2007 | 08:48 PM
  #36
1racerdude's Avatar
They will sell ya anything. Personally I don't care if Ya run two of them it's your engine. Is it just for bragging just to say ya got one?????If ya put the vacuum over 10/12 inches where ya gain a little HP from it ya suck all the splash oiling down and it don't get to where it needs to get. Like I said a dry sump is different as most everything is pressure fed. 12' only gains ya about 10-12FWHP on a 427" SBC that ran in the 7's with hose. I personally saw this at BES in Ohio.
MY EXPLENATION.
You have never run/owned one and suddenly you are an expert.
Old Oct 29, 2007 | 08:53 PM
  #37
95ttoplt1's Avatar
MY EXPLENATION.
Who are you talking too??
I certainly hope you are not talking to me, after I asked if you could explain the points in your post. I am inclined to think you are just continuing the witty banter with your estranged son.
Old Oct 29, 2007 | 08:55 PM
  #38
FASTFATBOY's Avatar
DAMNIT I AM LAUGHING MY *** OFF
Thanks for the laugh dude, really
He sits on here and posts like he goes to Engine Masters competition every year, with an engine HE built! 6500 posts! Hasn't built an engine in TEN! Years!! Has only built 3 or 4 in the last 20 years
BTW learn how to SPELL it's EXPLANATION, not EXPLENATION
-10 spelling LOL
David
Old Oct 29, 2007 | 08:56 PM
  #39
1racerdude's Avatar
Nope not you. You are inclined correct. And he is a total laughing matter
Internet schollar he is
Old Oct 29, 2007 | 08:58 PM
  #40
95ttoplt1's Avatar
Ok, well continue, you guys crack me up and I learn a lil something.
Either way, I always seem to get the pro's and cons.
Old Oct 29, 2007 | 09:00 PM
  #41
1racerdude's Avatar
  #42
mdacton's Avatar
Son, watch them lips......hard head makes for a soft ***
Originally Posted by FASTFATBOY;
Sorry, I will go get a switch
Old Oct 29, 2007 | 09:02 PM
  #43
FASTFATBOY's Avatar
MY EXPLENATION.
You spit this crap out like you build these engine on a DAILY basis.....what a damn joke.
BTW here is a little VID for ya, got one of YOUR car? Lets see it.
http://www.youtube.com/watch?v=0WConSQhjd0
Do the math on that 11.60 HA HA
David
Old Oct 29, 2007 | 09:07 PM
  #44
FASTFATBOY's Avatar
If nothing else his wanna be self is good for a laugh. He cracks me up posting this crap on here so he can be somebody.
BTW MD where did those quotes come from?
David
Old Oct 29, 2007 | 09:08 PM
  #45
95ttoplt1's Avatar
From GMZ website:
Net vacuum in a wet sump drag race engine should not exceed 15" hg max at maximum rpm. Many engine builders recommend 10" to 12". Dry sump engines can be run at 20" hg net. Check your vacuum on the dyno or on the track. Install a vacuum control valve if you exceed recommended vacuum level.
