Vacuum pump kits
Old Oct 2, 2007 | 07:10 PM
mdacton's Avatar
Vacuum pump kits
What gains would be had from a vac. pump on a race engine with aprox 600 flywheel h.p.? Is it worth looking into over an Evac system?
Old Oct 3, 2007 | 11:20 AM
1racerdude's Avatar
10-15 is what I have seen @ 12".
Old Oct 6, 2007 | 10:00 AM
68sixspeed's Avatar
yes, pretty typical on a small block; big blocks and large cubic in combo tend to give even more hp. On top of the ring seal improvements it also removes about 1/2 the air in the crankcase so there is less resistance pumping under the pistons and around the crank. (plus you don't get oil leaks while running!)
Interestingly- I have a 358 that likes the vacuum, but it was built with low tension oil rings and thin compression rings (.043" rings); when I dyno'd my 427sb, built with 1/16 nitrous compatible rings and std tension oil rings, it actually lost 10hp- likely due to too much ring seal and cylinder wall friction.
-Dan
Old Oct 27, 2007 | 04:44 PM
95ttoplt1's Avatar
Anyone find a kit that would work with an LT1 accessory drive system? Or maybe an electric version?
Old Oct 28, 2007 | 11:22 AM
flyinZ's Avatar
check out www.starvaccumpumps.com they've got one that should work, and its not real pricey. I think Summit might sell an electric version.
Old Oct 28, 2007 | 12:29 PM
tapout911's Avatar
Hmm that link directed me to a search for a different kind of pump....
Old Oct 28, 2007 | 01:27 PM
JohnnyPappis's Avatar
Link dosent work could you fix it for us this is somthing i really need to look into
Old Oct 28, 2007 | 01:42 PM
Stephen 87 IROC's Avatar
Here's your only real choices for a vacuum pump. There are probably a few others but these are the top 3 used in racing.
http://www.starvacuumpumps.com/catalog.php?cat=1
http://www.moroso.com/catalog/catego...?catcode=17200
http://www.gzmotorsports.com/vacuum-pumps.html
Old Oct 28, 2007 | 01:55 PM
flyinZ's Avatar
Yea, there's the site I ment to copy..Im computer retarded..sorry about that,heh.
Old Oct 28, 2007 | 04:52 PM
FASTFATBOY's Avatar
Thunder Racing sells an electric vacuum pump kit.
David
Old Oct 28, 2007 | 05:56 PM
mdacton's Avatar
http://www.thunderracing.com/catalog...&sid=798#P6515
Thunder kit only pulls 7" of vac. is that enought to even do anything?
I am using a low tension ring set and they are even back cut some.......I have not made the descison on the vac pump yet
Old Oct 28, 2007 | 06:09 PM
SStrokerAce's Avatar
Don't bother with a electric kit....
Reher Morrison has a nice kit
FWIW the better the ring seal the more power and vacuum are in it. IF you can get over 20" you are spending a LOT on rings and pistons.
Bret
Old Oct 28, 2007 | 06:28 PM
mdacton's Avatar
Reher-Morrison is the originator of the Vacuum Pump kit. This kit is designed to take the hassle out of installing a vacuum pump. The complete Vacuum Pump Kit will save you time and money.
Benefits of the Reher-Morrison Vacuum Pump Kit:
· Lowers crankcase pressure to minimize windage
· Improves ring seal for more power
· Allows use of low-tension piston rings for less friction
· Reduces blow-by, intake charge contamination and detonation
· Reduces oil leaks for lower maintenance and improved safety
Reher-Morrison Vacuum Pump Kit includes:
· Moroso three-vane vacuum pump
· Mandrel, pump and crank pulleys
· Breather/catch tank with separate mounting bracket
· -10 and –12 AN fittings
· -12 braided stainless hose
· Vacuum relief valve (Not shown above) -or- New! Option! Click Here
· Liquid filled vacuum gauge (Not shown above)
Price: $799
http://www.rehermorrison.com/
Old Oct 28, 2007 | 08:54 PM
95ttoplt1's Avatar
So if 20" is too much and 7" is not enough, what would be ideal? And are most of the pumps adjustable?
Old Oct 29, 2007 | 07:56 AM
FASTFATBOY's Avatar
10 inches is max for a streetcar, it kills wrist pins over that. Racecar, get as much as ya want as long as it is a pure trailer queen.
David
