Usual Damage internally for Spun bearings?
Old Oct 22, 2007 | 07:16 PM
NemesisLT1's Avatar
I am considering purchasing a shortblock LT1 from my freind who spun a bearing or two after his oil pump went out. He hasnt had the chance to open it up, What kind of damage am I looking at, he only wants 100$ and I am looking for a cheap block that I can bored out and make into a stroker motor.
thanks
Old Oct 22, 2007 | 07:53 PM
Kwiksilverz28's Avatar
Crank, rods. Hopfully did not heat up too bad and damage main caps....
Old Oct 22, 2007 | 07:59 PM
MachinistOne's Avatar
If it spun a main bearing you may have a worthless block, tell him $150 upon confirming that the block is good. If he's a friend, he will not make you play roulette.
NemesisLT1's Avatar
from what I was told, there is no damage to the tops of the pistons. Thats the farthest he went to look before he got a used shortblock elsehwere.
Old Oct 22, 2007 | 08:47 PM
rallysport92's Avatar
With spun bearings the only other concern would be the main caps which are not expensive unless u go with billet caps and the bearings were gonna have to be replaced anyway for a rebuild so $100 bucks for that short block is real good. Good luck!!
Old Oct 22, 2007 | 08:56 PM
It will take out the block side too, not just the cap
If the housing bore is damaged but repairable you are looking at new caps, line bore/hone - which can run you $250 so is it really a great deal at that point? And even if it doesn't look damaged, you will still need to have the housing bore checked out because the heat can put things out of spec.
My point is don't just blindly buy something, make him agree that the block has to pass a magnaflux and be usable.
Old Oct 23, 2007 | 11:50 AM
jester151315's Avatar
he said he wanted to build a stroker, so in this case you will get new rods and pistons and crank, so you should be good with everything, except the main bearings which may need to be line honed, this will cost about 200$ given it hasnt been damaged too bad, and hasnt been done before.....
like was said before pay him once it is confired block is good
ducttape1975
Jul 10, 2015 06:29 PM
colts0455
Jul 7, 2015 07:19 PM
robyyzpapa
Jul 7, 2015 10:05 AM
MadMav
Jun 15, 2015 09:51 PM
jackpawt883
Feb 26, 2015 09:04 PM
