tpi stealth ram/ mpfi sbc stealth Ram
Old May 23, 2005 | 11:16 PM
  #31
SStrokerAce's Avatar
Re: tpi stealth ram/ mpfi sbc stealth Ram
I usually just make a o-ringed plug on the lathe and throw it in there.
Bret
Old May 23, 2005 | 11:25 PM
  #32
Blownbird355's Avatar
Originally Posted by Rpm280
I am thinking of having the back part of the "box" that sticks under the cowl cut at an angle and having metal welded there so that it will "slant" downward under the cowl so that it will fit. I don't mind a cowl hood or other aftermarket hood (plan to get one anyway) to clear the part of the intake closer to the front of the car that would be left the height as it came from HOLLEY, but I have a daily driver, so I don't want to cut the cowl.
So basically , I am saying just have someone cut , and angle the manifold down in the back so it will fit under the cowl overhang.
Maybe that's what he meant? Or at least thats what i mean. LOL
Red
Yeah RPM and I are on the same page but it seems that the intake was cut.
By lookin at the pic SScya posted looks like you may be able to cut out a little less would have a hard time R&R then Manifold while engine is in.
Old May 24, 2005 | 03:01 PM
  #33
sseeya's Avatar
Originally Posted by RedIrocZ-28
Question, why is it that you guys cramming the HSR into a 4th gen are using a dizzy? I'd love to get rid of it completely and use a 95+ vented opti or an LTCC setup. Why not just plug the hole?
Actually when Bret did the intake for me he plugged the distributor hole. I took the plug out and am running a distributor because I just got tired of screwing around with the Opti. Plus I'm eventually going to throw a crank trigger on it.
G-BODYT56
Jan 14, 2022 11:14 PM
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
zk06
Sep 9, 2015 11:39 AM
