tpi stealth ram/ mpfi sbc stealth Ram
Hi kinda of a odd question but does anyone know which would beable to work with on a lt1. and what modifications would be required to make it happen. Its a good mainfold from holley and it might be cheaper that by a sheetmetal one in the long run.
Re: tpi stealth ram/ mpfi sbc stealth Ram
Originally Posted by SStrokerAce
What you want to run carbs?
No, although I suppose that would be the easiest manifold mod.
I was thinking more in terms of injectors at the bottom and two "4-barrel" throttle bodies up top, OR a forward facing TB mounted on the front of a plenum box which is bolted to the top of the manifold. Or for that matter, you could mount it on the rear for cowl induction.
that's basically a HSR then....
Well, I haven't driven over to Summit with a measuring tape, but if I'm not mistaken; the tunnelram is much taller than the SR.
The Holley Stealth Ram is about 3" taller than the stock TPI manifold. Its so much taller in fact that it will "rub" on the underside of a Camaro Hood, and a Firebird Hood will need to be clearanced on a 3rd gen. For you, with a 4th Gen, well, All I can say is gool luck, The miniram/LT1 intakes are short short short. The stealth Ram is very tall.
I'm going to run out to my car a sec and see how tall the HSR is standing off the block. 10.5" off the block to the top of the fins on the HSR. You will Require a cowl hood and Possibly will require the modification of the area at the firewall, and the actual overhang of the cowl area at the base of the windshield.
In a 3rd gen its lots easier to fit one in as the intake manifold isn't wedged under the cowl. Other than that, its a 1205 Gasket (roughly) for the ports on the HSR, and you'd need to fill in/block off the hole for the distributor.
http://community.webshots.com/photo/...28436647YGYqOs
Mike you gettin close to running that yet?
Bret
Bret
Originally Posted by 97WS6SCharged
That's really making me want to get back to work on my S10 project.
Mike, I'll be interested in the results once you get it done.
Bret
Originally Posted by SABLT194
Mike,
Bring that baby over to Kauffman's south of Dillsburg and we'll smack a tune on her!
Steve
Steve
The motor is up and running. When we installed the Stealth Ram, we also switched from the Accel Gen 6 to the newer Gen 7 DFI and it needs to be tuned.
I'll keep you in mind, but I'd really like to have it done by the same guy on the same dyno to get a more accurate idea of exactly how much difference the manifold makes.
Bret
Bret
