Too much compression?
Old Jul 9, 2007 | 06:28 PM
spray004's Avatar
I'll be getting my block and rotating assembly back from the machine shop in a week or so. I'll be building a 355 and have started wondering if I'll have too much compression for my rotating assembly. I calculated that I'll have around 10.7:1 static CR and 8.47:1 dynamic CR. My bottom end consists of a Scat 9000 cast crank, GM X-rods w/ Pioneer bolts, cast rings and Speed pro hyperuetetic flat taps. I don't plan on turning over 6000 rpm and it will be a weekend street engine. I'll be running Brodix IK180 heads so I think I'll be ok for 93 octane pump gas, but I'm concerned that it might be a little much for my rotating assembly. What do you guys think?
Old Jul 9, 2007 | 06:59 PM
rskrause's Avatar
Moderator
Not as long as it doesn't detonate. But those HE pistons do NOT like detonation.
Rich
Old Jul 9, 2007 | 07:10 PM
spray004's Avatar
Rich
I think I should be ok with aluminum heads and 10.7:1 compression. Another question someone else brought up is the head gasket I had planned on using. I was looking at the Fel-Pro 1094 which is the .015 compressed thickness head gasket that Fel-Pro has. Someone mentioned that the steel wire around the bore might mess up the aluminum heads. Is anyone out there using this gasket with aluminum heads?
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
