Template for a 3.750 stroke clearance
Old May 22, 2003 | 07:59 PM
FASTFATBOY's Avatar
Does anyone have/make a lower end "template" to clearance the lower end of an LT1 for a 3.750 stroke crank to swing? I have cap screw rods. I want to get around all the mocking up and grinding deal. Not all of us have access to a CNC machine.
David
Old May 22, 2003 | 08:31 PM
OldSStroker's Avatar
Every brand of crank and rod combo is a little different. I don't think a template would work.
CNC would rarely be used just to clearance a block unless it was machining the whole bock, and in the case of GMPP cnc Bowtie blocks, you still need to check/clearance them the old fashioned way.
No free (or cheap) lunch. Mock it up...grind it out.
It's a dirty job, but someone's got to do it (like spellchecking).
My $.02
Old May 23, 2003 | 04:55 AM
rskrause's Avatar
Moderator
Most 3.75" combos experience interference at the bottom of the bores. With a high lift cam, you may get a little interference from the head of the rod bolt/cam. I suggest grinding the head of the bolt, not the cam . Sometimes a little clearancing of the pan rails is needed. A couple of hours with a die grinder will do the trick. Good job to do while having a beer, it's not too technical and it's hard to screw anything up. No biggy if you take a little too much. Not like head porting (don't ask me how I know).
Like the old guy said, mock it up and grind away at the point where parts make contact.
Rich Krause
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Fastbird93
Jul 11, 2015 04:37 PM
