Question about Dynamic Compression Ratio (DCR)
Old May 21, 2003 | 01:21 PM
AdioSS's Avatar
West South Central Moderator
Using this -> http://www.rbracing-rsr.com/comprAdvHD.htm
It says that my little stock longblock iron head LT1 has a DRC of 9.86:1 at sea level. From what I've read in the Advanced Tech Forum here, that should be way too high especially considering the iron heads. But GM built this to run on 87 octane.
Does this calculator really use duration @.050 like it says?
Here is what I put in. 4" bore 3.48" stroke 5.7" rod 10.1CR with 22* ABDC (191/196@.050, 111LSA 106.5 ICA)
When I put in my cam specs for what I was hoping to use, it gives 44* ABDC and with 11:1CR that would bump the DCR up to 9.97:1... I don't think I would have a problem with this... Would I?
Old May 21, 2003 | 01:29 PM
ImportsRsloths's Avatar
didnt GM build the LT1 for 91 octane???
Old May 21, 2003 | 01:41 PM
AdioSS's Avatar
would they really build an engine specifially for the police and taxis that would only work with 91 or better? I don't think so.
Old May 22, 2003 | 07:27 PM
OldSStroker's Avatar
Re: Question about Dynamic Compression Ratio (DCR)
I got 8.60 DCR on your base engine using another program. That sounds much more reasonable than 9.86.
You entered 22 deg, the intake opening event instead of 55 or 56 degrees ABDC, the intake closing event. Try 55.5.
Old May 22, 2003 | 07:42 PM
AdioSS's Avatar
The site says to use the duration @.050. When I put the stock impala specs in Desktop Dyno, it gave me:
IVO (BTDC)=-11
IVC (ABDC)= 22
EVO (BBDC)=33.5
EVC (ATDC)=-17.5
Old May 22, 2003 | 08:26 PM
IVO (BTDC)=-11
IVC (ABDC)= 22
EVO (BBDC)=33.5
EVC (ATDC)=-17.5
Dear
In most cases I'm familiar with, DCR uses total duration or "advertised duration". After all, with the lifter at .050, that's .075 open at the valve with 1.5rr, hardly a closed cylinder which can contain compression.
By definition, DCR uses cylinder volume @ intake valve closing
This 191/196 @ .050 cam is actually about a 258/264 total duration cam. IMO, the calculator needs total not .050 numbers.
My $.02.
Old May 23, 2003 | 03:58 AM
rskrause's Avatar
Moderator
Originally posted by OldSStroker
Dear
My $.02.
As usual, the old stroker said it well. It makes no sense to talk about seat timing and then use duration at 0.050" for the calculations. Discussion of DCR is usually based on seat timing and hence on advertised duration.
Rich Krause
Old May 23, 2003 | 03:00 PM
Soma07's Avatar
Its a typo, use the seat duration instead and you should get more accurate results. Only catch is I can't find the IVC for a stock cam anywhere...
Old May 23, 2003 | 05:11 PM
AdioSS's Avatar
OldSStroker, have you measured the stock impala cam to find the seat duration?
ThankSS for clarifying everything guys
Old May 23, 2003 | 05:36 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
silly question-
whats "ABDC"
(if anyone answers "trey in 1st grade.... )
Old May 23, 2003 | 07:26 PM
cASe SenSiTive's Avatar
Exposed Member
Originally posted by treyZ28
silly question-
whats "ABDC"
After Bottom Dead Center
Old May 23, 2003 | 07:39 PM
rage366's Avatar
ahh, compression questions...the beauty of build up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
