T/C question
Old Aug 3, 2002 | 07:29 PM
new-LS1's Avatar
Post T/C question
Im currently planning on going with a VIG 3600 with #7 pump. Everybody i speak to says this converter stalls at (around) 3600. Yanks website says "4300" other people I speak to say 3600-3800. Whats up with this? The car isn't a daily driver, and im looking for a 4000+ stall here. Is there a VIG 4000? but will it stall at 4000? I have until the 12th to make up my mind. (reason being Chuck @ FLP get back from vacation on the 12th) he will start building my Level IV trans then. The purpose of this post is to make up my mind on with T/C to go with. Drag/strip/steet is all this car will see, with maybe the ocational weekday drive. My current Stealth Thruster 3200 T/C feels WAY TO CLOSE to stock, I need something with ***** to go with my new FLP trans Thanks everyone...
2000 Camaro Z28
CAM'ed, YANKED, GEARED, CUSTOM TUNED, HOOKER LONGTUBES, CUSTOM X-PIPE DUAL EXHAUST, AND ON A DIET. ST3200, TR224 .564 112lsa, ED WRIGHT TUNING, AND COMPCAMS VALVE-TRAIN:TITANIUM RETAINERS, MOLY PUSHRODS, 918 SPRINGS ETC..
Old Aug 3, 2002 | 08:26 PM
a walker's Avatar
Post
Torque convertors vary with stall speed. The more torque an engine makes, the more the same convertor will stall. I know LS1 cars can efficiently use a higher stall than LT1's since the torque isn't down low. Did you ask Chuck what he recommends? He is very good at putting together a nice trans package and can help you find what you're looking for. BTW, I hope you don't plan on driving your car for a while. Mine's been at FLP for over a month for my trans. I had a Level 4 built four months ago, and it didn't last too long. But they are working with me, I'm getting pretty much a whole new trans for a couple hundred bucks.
Blue 1994 Z28
Moroso CAI, March underdrive pulleys, Jet throttle blade, Comp Cams 1.6 rr, Accel 300+ ignition, HPPIII, Accel adjustable fuel pressure regulator/gauge, Nitrous Works wet kit (175hp), FLP race-prepped 4L60E, Coan 2800 rpm convertor, LS1 driveshaft, 4.10 gears, cat removed, Flowmaster American Thunder. Moser 12 bolt soon.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Redbird
Jul 29, 2002 06:23 PM
