Timing issues on a 383
Old Aug 3, 2002 | 05:34 PM
newby's Avatar
Question Timing issues on a 383
Alright, anyone have suggestions as to how much initial timing to run? I have mine set at 12, but I was talking to a guy at autozone who said stroker engines like to be closer to 17 initial, and that it would help my engine run cooler if I did change it. Any input?
1986 Z28
383 ci Stroker, Dart Sportsmen 2 heads, roller rocker arms, Crower Hot Street Beast cam, edelbrock 750cfm carb and performer rpm intake, Corvette Servos, shift kit and 2600 rpm stall convertor, 3.73 gears and Eaton limited slip posi rearend.
Old Aug 3, 2002 | 11:50 PM
kmook's Avatar
Advanced Tech Moderator
Post
This should be posted in a regular tech forum. And since you already made the same post in 3rd Gen, i will close this thread.
Thank you.
Advanced Tech Posting Guidelines
D1SC383LT4
Jan 26, 2015 01:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
deadmanrunning
Jan 3, 2015 01:12 PM
Snoman73
Nov 17, 2014 07:22 PM
