specific cam question
Old Oct 21, 2007 | 05:27 PM
seawolf06's Avatar
Consider I'm looking at a specific range of Intake Closing angles to achieve a DCR around 8.5+-0.2. I would also like as much overlap as possible, around 71 @.006/15 @.050.
Would it be a bad idea if these numbers are achieved using a LSA that is retarded 4 degrees or less from the ICL? (i.e. 282/288 on a 106 LSA and 110 ICL)
Please give an explanation. The setup is:
Forged 355 LT1
11.6:1 SCR
Head flow slightly better than LT4 stock with better exhaust %.
M6/4.11 gear
Basically, I'm looking for something with similar timing events to the cc306 with a lot more lift.
Thanks.
Old Oct 21, 2007 | 11:17 PM
OldSStroker's Avatar
Forged 355 LT1
11.6:1 SCR
M6/4.11 gear
Thanks.
Why?
IOW, what is it you are trying to achieve? I mean your performance goals for the car, not what valve events you want or think you need.
Old Oct 22, 2007 | 01:36 PM
seawolf06's Avatar
Well, situation has changed again, so this is really a moot point now, haha.
I am trying to have a fast street car. Not a DD, but a strong weekend warrior. I need to stay within the limits of the stock pcm, but I want to push it to around 6700 RPM.
Old Oct 23, 2007 | 12:31 AM
SStrokerAce's Avatar
If it's a street car it's a bad idea, hell doesn't matter what kind of car it is, it's a bad idea.
Old Oct 26, 2007 | 11:36 AM
seawolf06's Avatar
Would installing it retarded 4 degrees make any difference in the DCR or is that something that is strictly ground into the cam?
Old Oct 26, 2007 | 04:48 PM
worse idea
Old Oct 27, 2007 | 04:47 PM
seawolf06's Avatar
Is there an answer why?
Old Oct 28, 2007 | 06:07 PM
Retarding the cam is why
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
