Seat pressure problems
Old Jan 17, 2008 | 01:45 PM
Viking's Avatar
Hi
Was to install my PAC-1220 springs in my AFR210 Eliminator heads, but ran into problems.
Due to the design of the Bee-hive retainer my max install height is 1.84" with +0.1" valves.... That would give me 170lbs seat pressure.....
Is it true that you loose appr 20lbs after break in?
What alternatives do I have?
- is there a +0,050" 8mm 10 deg valve keeper?
- is there a thinner spring seat?
- is there another retainer?
- find another spring?
Old Jan 17, 2008 | 07:16 PM
rskrause's Avatar
Moderator
Good springs are not going to lose much pressure.
Rich
Old Jan 17, 2008 | 07:50 PM
MachinistOne's Avatar
You need different springs.
Like Rich said, you should not see more than 5-10 lb loss with performance springs.
Old Jan 18, 2008 | 02:07 AM
Viking's Avatar
So if I get them down to 160lbs@seat it should be OK with HR lifters?
Otherwise I guess I'll have to buy PAC-1518 springs....
Old Jan 18, 2008 | 04:53 AM
rskrause's Avatar
Moderator
What seat pressure does the cam manufacturer call for?
Rich
Old Jan 18, 2008 | 05:19 AM
Viking's Avatar
Dont know
My cam has the old XE lobes that are PITA to control....
Since its supercharged I was thinking of 150lbs at seat.
Old Jan 18, 2008 | 08:47 AM
Viking's Avatar
My 2 options
PAC-1518 would give me
150lbs@1.74"
330lbs@1.163" (full lift)
Coil bind 1.08 + 0.06=1.14" OK
CC 26918
150lbs@1.73
365lbs@1.15" (full lift)
Coil bind 1.10+0.06= 1.16" scary close or?
Old Jan 18, 2008 | 09:30 AM
rskrause's Avatar
Moderator
Isn't there a good dual spring you could use? I'd like to see more on the seat.
Rich
Old Jan 18, 2008 | 10:10 AM
Viking's Avatar
My current pac-1220 would give me 170@seat, but that is maybe too much?
Maybe I can mill down the spring seats some, 0.5mm, that would give me around 163lbs seatpressure
/N.
Old Jan 18, 2008 | 01:58 PM
rskrause's Avatar
Moderator
Why do you think 170# is too much? Sounds good to me.
Rich
Old Jan 18, 2008 | 02:07 PM
Viking's Avatar
Hyd.roller lifters?
I thought 150 lbs was a general rule for max seat load with hyd.roller lifters?
I could give it a try and swpa springs to 261918 if I break any lifters, but I like to do it right first time......
/N.
Old Jan 18, 2008 | 02:52 PM
rskrause's Avatar
Moderator
It should not break your lifters. Too high an open pressure is the issue, not the seat pressure.
Rich
Old Jan 18, 2008 | 02:55 PM
JustNO's Avatar
My springs are around 180-190# seat pressure and 470# open. Its too much for my hyd. roller setup, but I used Morel Hyd. Lifters and since 1 year there is no problem.
(BTW I will change my springs to PAC 1518)
Old Jan 22, 2008 | 09:59 AM
Yeahdoug's Avatar
CAn you get +0.050" locks?
Old Jan 22, 2008 | 12:10 PM
1989TransAm's Avatar
Another option. Manley makes a nice beehive spring that is worth consideration. Part number is 221428.
It has 150# on the seat at 1.800". Has 355# on the seat at 1.200" height. Dimensions are essentially the same as the Comp 918.
