Seat pressure problems
Hi
Was to install my PAC-1220 springs in my AFR210 Eliminator heads, but ran into problems.
Due to the design of the Bee-hive retainer my max install height is 1.84" with +0.1" valves.... That would give me 170lbs seat pressure.....
Is it true that you loose appr 20lbs after break in?
What alternatives do I have?
- is there a +0,050" 8mm 10 deg valve keeper?
- is there a thinner spring seat?
- is there another retainer?
- find another spring?
My 2 options
PAC-1518 would give me
150lbs@1.74"
330lbs@1.163" (full lift)
Coil bind 1.08 + 0.06=1.14" OK
CC 26918
150lbs@1.73
365lbs@1.15" (full lift)
Coil bind 1.10+0.06= 1.16" scary close or?
150lbs@1.74"
CC 26918
150lbs@1.73
Hyd.roller lifters?
I thought 150 lbs was a general rule for max seat load with hyd.roller lifters?
I could give it a try and swpa springs to 261918 if I break any lifters, but I like to do it right first time......
/N.
/N.
My springs are around 180-190# seat pressure and 470# open. Its too much for my hyd. roller setup, but I used Morel Hyd. Lifters and since 1 year there is no problem.
(BTW I will change my springs to PAC 1518)
Another option. Manley makes a nice beehive spring that is worth consideration. Part number is 221428.
It has 150# on the seat at 1.800". Has 355# on the seat at 1.200" height. Dimensions are essentially the same as the Comp 918.
