Results of stepped headers/merge collectors vs standard headers
All eyes, ears n teeth if you can support what ya said.
The level of this discussion has gone well beyond my experience or understanding but I have a header question that might relate to this.....
I've seen the NASCAR guys concentrating on something I've heard referred to as a "merge collector", I think it is, where the COLLECTOR necks down just beyond where the 4 head pipes come together and then opens back up slowly on the far side. Looks suspiciously like a venturi to me.
Does that design have any merit for a typical street or street/strip motor or is that also in the realm of "black magic" like stepped headers? Do the two work hand in hand?
Again, all eyes, ears n teeth if someone has facts.
I know it’s apples to oranges, but it shows some more “expert” advise recently given regarding headers. My buddy has a late model EFI 427ci (small block) Mustang. He recently decided to change from…an approx. 240/250 dur. 550/575 lift hydraulic roller cam, AFR 205 heads, and converted Victor Jr intake…to an approx. 250/250 dur. 600/600 lift solid roller cam, AFR 225 heads, and converted Super Vic intake. Ed Curtis helped him spec all the new parts and recommended he also change from his old standard Hooker 1.75" LTs to new Kooks 1.875" to 2” stepped headers with a merge collector.
I also read the LSx forums a lot, and get the impression that Lou’s 1.75" merge collector super duper LTs, and the larger stepped/merge collector Kooks (and other similar brands) are the ones indicated to produce the best results.
Call me crazy, but it sure seems like your motor (398ci, 7000 rpm, screamer) would benefit from the larger stepped/merge collector design…why it doesn’t I don’t know.
having just installed a 396 LT1 with a GM847 cam and big heads I'm also curious.
I went with AS&M mid-length headers (1.75" primaries), but I'm curious if there's more options out there that would retain ground clearance.
carguyshu
Jan 22, 2017 11:19 AM
