Quick question about main bolts
Old Apr 17, 2005 | 06:02 PM
12Second3rdgen's Avatar
Quick question about main bolts on a 4 bolt main small block chevy. This is a late model block from an L31 crate engine (350HO).
It has 4 bolt mains, with bolts with a provision for a windage tray. Do you guys think it is necessary to buy aftermarket main studs for my buildup? Setup is:
Probe forged pistons, scat forged cap screw I beams and a cast eagle ESP 3.75 stroke crankshaft.
I am looking to save some money and I was hoping to reuse the stock hardware.
Thanks guys! Sorry for asking so many questions lately, but we are getting sooo close .
Old Apr 17, 2005 | 09:30 PM
rskrause's Avatar
Moderator
Re: Quick question about main bolts
I think you can use what you have, no problem.
Rich
Old Apr 18, 2005 | 02:54 AM
captaindbol's Avatar
A set of ARP main bolts is some pretty cheap insurance if you aren't going to use a windage tray. $25.88
summit part # arp 134-5202
Old Apr 18, 2005 | 03:05 AM
I am going to use a windage tray though, and summit price for the arp studs for a windage tray is $75.00
This motor has under 3000 miles on it when I tore it apart, and it wasnt hurt when I pulled it apart .
Old Apr 18, 2005 | 06:23 PM
stealthblack's Avatar
Ive done some fairly idiotic things with stock SBC parts and had them live;also back in the days that was all racers had and they held together.Anyway ive had em at a 7200 rpm redline, no problem-- With that said I run full ARPs or equivalent in my car and recommend it to anyone i help put a motor together.I understand money being tight, trust me, and at a low to mid power level[i dont know yours] it shouldnt be a problem, but i'd personally rather go mac and cheese for a while than have my caps screwing around.
ZZ series had those bolts, and theyre modded to the far side of 4xx hp all the time.
JMO
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Jan 11, 2015 03:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
