Question concerning Compression calculator
Old Jan 31, 2005 | 04:54 PM
SS Mark's Avatar
Why does the bore sizr say 4.0 after the calculation is done when I put in 4.03?
Here:
Input Parameters Are the Following:
* Cylinder head Volume (CC) = 56.00
* Piston Top Volume (CC) = 31.00
* Cylinder Bore (Inches) = 4.0
* Cylinder Stroke (Inches) = 3.75
* Deck Height (Inches) = 0.006
* Head Gasket Thickness (Inches) = 0.039
Computation Results:
# Computed Compression Ratio is 9.1 to 1
I would just like to know if it used a 4.03 bore for the calculation or not. Im assuming if I didnt overall compression would be lower but I would like to know how much.
-Mark
Old Jan 31, 2005 | 05:02 PM
rskrause's Avatar
Moderator
Re: Question concerning Compression calculator
The difference would be ~0.15.
Rich
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Red_94Formula
Jan 22, 2015 12:17 AM
