How to figure out how much....
Old Jan 31, 2005 | 05:53 PM
Rob(94Hawk#319)'s Avatar
Fuel injector is gonna be required for any given engine combo, ie: stock 24 lbs, mild 355, 30 lbs, etc... Do you just go with a small one, see what duty cycle you're injector is putting up with and adjust from there? Or is there an actual formula?
Thanks.
Old Jan 31, 2005 | 10:52 PM
Re: How to figure out how much....
There are numerous online calculators for injectors. The basic equation is fairly simple, and will get you in the ballpark. Just about all of them use a brake specific fuel consumption (BSFC) of 0.50 #/HR/HP for a nomally aspirated engine, and recommend limiting duty cycle (DC) to 80% (0.80).
(flywheel HP X BSFC) / (# cyl X DC) = injector required
Example:
(400 HP X 0.50) / (8 X .80) = (200) / (6.4) = 31.25 #/HR
A well tuned race engine might approach a BSFC of 0.45 or better. A nitrous or blower engine might need 0.55, a turbo application might be even higher. Some injectors will accept a DC of 0.90 better than others, but the conservative values used in the example above are the best place to start.
Old Jan 31, 2005 | 10:59 PM
Excellent, that's exactly what I needed. Thanks Fred!
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
