Replacing Valve Seals with Heads on Block.
Old May 24, 2003 | 10:30 AM
Zero_to_69's Avatar
Hi All,
Long time no see!
I know this isn't too advanced for most of you, but it may help others with similar questions:
I'm about to change my valve seals. I have the heads on and
110 PSI pressurizing the cylinder.
I am using a screw type spring compressor.
The spring is compressing fine, but the retainer is not moving down
the valve stem. I tried tapping the top of the compressor in hopes
that the spring and compressor would slide down the valve
shaft, but no luck.
Here's a link with some photos:
http://members.rogers.com/tdese739/i...compressor.jpg
http://members.rogers.com/tdese739/images/keepers.jpg
http://members.rogers.com/tdese739/images/toolhead.jpg
Am I doing something wrong? Has anyone run into this problem
before?
Thanks for any tips.
Old May 24, 2003 | 11:33 AM
Brandy's Avatar
I've had to smack the retainer/locks with a mallet before to get them loose. Might be hard to do with that compressor though.
Old May 24, 2003 | 01:35 PM
rasilverbird's Avatar
Take a socket that will fit around the locks, and will rest on the retainers, and tap it with a hammer a few times. You need to break them loose so they will separate. You should be good to go after that.
Old May 24, 2003 | 02:02 PM
Zero_to_69's Avatar
Thanks guys, I figured they were tight, but I didn't want to ruin
the retainers.
Much appreciated!
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
