oil pressure prob
Old Jun 24, 2004 | 01:32 PM
southern94's Avatar
oil pressure prob
just rebuilt my motor and i am not getting oil to the heads it is filling up the oil filter and seems to lubbing the crank i dropped the tranny and pan it was dripping from the mains but i am not getting any oil in the rocker valley any clue?
i checked out the restrictor plug in the back of the block it's fine the plug in the back of the crank is fine it has a double roller timing chain and ls6 oil pump the spacers i made sure where done right i packed the oil pump with assmb. lube anyone?
Old Jun 24, 2004 | 03:54 PM
Zero_to_69's Avatar
Check the restrictors behind the cam gear. There are three
holes that need to be capped.
If those holes are left open, the oil will run back down the timing
chain cover and into the pan.
Old Jun 24, 2004 | 04:20 PM
1racerdude's Avatar
If you have the flywheel off take a look (remove) the restrictors and check for trash. If the holes are smaller then .100 take them and drill them.If this is a street motor you don't want restrictors in it.If this is the case,plug the L&R oil galley holes with pipe plugs and put it back together and check clearance to flywheel.Another thing that my cause it is a small BC cam with the wrong lifters.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
