oil pressure prob
oil pressure prob
just rebuilt my motor and i am not getting oil to the heads it is filling up the oil filter and seems to lubbing the crank i dropped the tranny and pan it was dripping from the mains but i am not getting any oil in the rocker valley any clue?
i checked out the restrictor plug in the back of the block it's fine the plug in the back of the crank is fine it has a double roller timing chain and ls6 oil pump the spacers i made sure where done right i packed the oil pump with assmb. lube anyone?
If you have the flywheel off take a look (remove) the restrictors and check for trash. If the holes are smaller then .100 take them and drill them.If this is a street motor you don't want restrictors in it.If this is the case,plug the L&R oil galley holes with pipe plugs and put it back together and check clearance to flywheel.Another thing that my cause it is a small BC cam with the wrong lifters.
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
