Need help with T/C lock-up switch
Old Aug 19, 2002 | 04:05 PM
SilverHawk183's Avatar
Post Need help with T/C lock-up switch
Got the switch in, and it does not work. Spliced into pin 42 Tan/Blk wire. When you are sitting still in drive and push it should it die. and if i can get it to work when do you use while raceing.
02 Silver Firehawk A4
Free mods
RWHP-323
RWTQ-333
60'-2.02
1/8-8.43
1/8-85.6
1/4-13.04
1/4-107.4
Old Aug 19, 2002 | 05:45 PM
kmook's Avatar
Advanced Tech Moderator
Post
This question is more proper for LS1 Tech, Your other thread there should net you an answer, If not after a few more days try posting back in Adv Tech. Thanks!
Ken
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
