Lets talk overlap and its effect on PA and NA motors
Old Aug 18, 2002 | 11:10 PM
LTOne4Fun's Avatar
Post Lets talk overlap and its effect on PA and NA motors
Which one wants what and why???
Old Aug 19, 2002 | 09:34 AM
Mikael's Avatar
Post
What's a PA motor.
Old Aug 19, 2002 | 09:41 AM
89ProchargedROC's Avatar
Post
power adder
Old Aug 19, 2002 | 07:52 PM
Josh-'04 GTO's Avatar
Post
Well...I'm not sure how "advanced" of an answer I can give you, but I'll give it a whirl.
Overlap is the amount of time that the intake valve and exhaust valve in the same cylinder are open at the same time. Heavy overlap is common in cams with large duration and tight lobe centers.
On a NA car, overlap is desirable as the exhaust stroke pulse helps to draw in the intake charge(remember, the intake valve is opening while the exhaust is still open). On a supercharged engine, this is not desirable as the exhaust valve opening while the intake is open allows your boost to blow right out the exhaust.
'97 Firebird Formula WS6
383 stroker, Ported/Polished heads with 2.00/1.57 valves, 1-3/4" headers, 2600 stall, blah blah blah.
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Nov 23, 2014 10:33 AM
guionM
10
Sep 8, 2002 11:08 PM
Brady
Jul 29, 2002 10:30 PM
