mixture distribution
Old Aug 28, 2005 | 02:04 AM
CCCCCYA's Avatar
maybe this doesn't belong here.. dunno.. Put it where it's appropriate if thats the case..
Anyhow, I'm switching to a carbed 383 LT1 setup, and I'm wondering if mounting the carb on the intake sideways will have a negative effect on mixture distribution. Reason for this is fitment mainly. Everything will "line up" better if I can mount the thing transverse. This is on a single plane Vic Jr. CNC.
Thoughts?
Old Aug 28, 2005 | 09:05 AM
rskrause's Avatar
Moderator
Re: mixture distribution
If it's a square bore carb it should make no difference.
Rich
Old Aug 28, 2005 | 09:36 AM
OldSStroker's Avatar
You mean rotating it 90 degrees looking down on it, right?
That puts the primaries near one bank and the secondaries near the other. Because the manifold wasn't designed for that kind of flow, I suspect mixture distribution might be compromised at anything less than wide open throttle.
Just my thoughts.
Old Aug 28, 2005 | 09:46 AM
rskrause's Avatar
Moderator
Just my thoughts.
Oopsie, you're right. when I wrote "square bore" I was thinking of square bore "double pumper" type race carbs which open all 4 at the same time. When I think of carbs, that's what is the default mode.
Rich
Old Aug 28, 2005 | 11:02 AM
Zero_to_69's Avatar
I'm going to agree based on the trial and error I've had with jetting combos.
My setup incorporates a single plane intake with a square bore Holley which
sits in the "normal' position (floats front to back).
When I'm swapping jets and checking plugs, I can see a noticeable variance
between the front and rear plugs (#1, #2 and #7, #8).
IE: Replace all of the plugs. Do a wide open pass and shut down.
I find that with jetting for street use (conservative primary jetting) amplifies
this imbalance.
Wish there was a method to have a jetting combo that works well on the street
and the track!
Old Aug 28, 2005 | 12:53 PM
1racerdude's Avatar
Originally Posted by Zero_to_69
I'm going to agree based on the tiral and error I've had with jetting combos.
this imbalance.
and the track!
The imbalance I have seen is the front is lean and the rear is rich. Is this your case?
It can be fixed with plentum mods and runner end mods in the plentum.It takes someone who knows what they are doing to do it right.
Old Aug 28, 2005 | 02:27 PM
CCCCCYA's Avatar
Sounds like sheetmetal modding is going to be much easier than making it work sideways. There really is nothing easy on these cars is there?
Thanks for the input fellas.
Dave C.
damnyankee36
Sep 9, 2015 07:06 PM
maverickmk
Sep 1, 2015 09:17 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
NEWBIE T/A
Nov 14, 2002 01:57 PM
WadeC
9
Oct 15, 2002 11:11 AM
