Wont rev beyond 5400rpm
Old Aug 25, 2005 | 01:27 PM
Viking's Avatar
Ok need ideas of what to try...........
Engine is a motown 415cui
- 9.0 comp
- CC306 cam
- HSR intake
- Jegs 197cc heads
- 58mmTB
- MSD 6AL system with MSD coil
- exhaust is SLP 1.3/4 headers, with dual 3" HF cats and free flow muffler.
- Procharger F1 9psi @ 5400rpm so far........
The problem is that the car wont rev beyond 5400 rpm, it just stops pulling? even with 9psi of boost, it just falls flat on its face............
Ive checked
- No rev limits in the ECM (fuelcut off and so on)
- plug gap set to 0.9mm
- fuel pressure is stable
- Spark tested fron 24deg to 32 deg with 9psi
The AFR under boost is at "safe" 10.5-11.0
Any ideas? the only thing that I havent changed on the engine is the distributor its still stock........
Old Aug 25, 2005 | 07:18 PM
IRACE87's Avatar
Re: Wont rev beyond 5400rpm
What are the spec of your valve springs and what is the preload on your lifters ?????
Old Aug 26, 2005 | 01:03 AM
Viking's Avatar
preload lifters 3/4 turn
Springs
1.440'' Springs
1.875'' Installed height, 130 lbs. seat pressure
Old Aug 26, 2005 | 01:39 AM
smoknta's Avatar
Try bypassing the 6AL.
Old Aug 26, 2005 | 02:48 AM
Viking's Avatar
I'll se if I can figure out a easy way of doing that.............the rev limit on MSD is set to 7000rpm.
/N.
Old Aug 26, 2005 | 03:51 PM
IRACE87's Avatar
Springs
1.440'' Springs
Preload the lifters with only 1/16 of a turn and give it a try.
What brand of lifters are you using ??
PAT
Old Aug 26, 2005 | 04:07 PM
Viking's Avatar
I doubel checked my fuel pressure a few minutes ago and it starts to drop at 5000rpm @8 psi .........Time for a boost a Pump.......
The lifters are Crane "anti-pump up" or "retrofit" or whatever they are called
Old Aug 26, 2005 | 05:19 PM
1racerdude's Avatar
Time for a BIGGER pump.
Old Aug 27, 2005 | 01:04 AM
Viking's Avatar
I already have the Walbro 255 High Pressure..........
is there any bigger intank pump?
/N.
Old Aug 27, 2005 | 08:03 AM
smoknta's Avatar
Put in dual Walbros....
Old Aug 27, 2005 | 10:58 AM
1racerdude's Avatar
Racetronics makes a duel intank or an Aeromotive external.
Old Aug 27, 2005 | 02:38 PM
Viking's Avatar
Cant find them on the webpage? links?
(my car is a L98 -89)
thx!
Old Aug 27, 2005 | 03:28 PM
1racerdude's Avatar
thx!
Ya won't,ya have to call them.
Old Aug 27, 2005 | 09:39 PM
smoknta's Avatar
Try www.racetronix.com
Old Aug 29, 2005 | 12:17 AM
Viking's Avatar
I've just pleced a order for a second walbro 340 high pressure. I will control it via the ECM or a hobbs switch set at 5-6psi..............
/N.
