Installing splayed main caps.
Old Sep 30, 2007 | 01:14 PM
jakesz28's Avatar
First off I will say I haven't really seen the in work process of installing splayed caps. Now I work in a non automotive machine shop and I would like to install some splayed main caps in a LT block. All I want to do is mill the blocks so they fit in the recessed area of the block. Then I plan on putting it on a boring mill and rough machining the new caps.
I would like some info from someone that has done this a few times.
I think I should check the registers on the block and see if the bore is offset one way or the other. Then when I machine the sides of the new caps to fit in the register I will want to try and make sure the bore on that is centered over the bore on the block. I plan on using a drill bushing while drilling the block for the splayed caps. But what are the chances of hitting the water jackets? Should I fill the lower portion of the block first? Then after I set the block up on the boring mill and indicate the front and rear caps in I can start opening up the new caps.
Does this sound like it will work or am I way off?
Thanks for any info you have to offer
Old Sep 30, 2007 | 01:33 PM
MachinistOne's Avatar
What caps do you have?
You should be using the 10* outer ProGram flat caps. They will not break into water when drilling for the outers.
The block registers will be cut to 7.500"(check your caps to make sure this is correct)
Get the right caps, and do not cut them, cut the block to fit.
Old Sep 30, 2007 | 01:52 PM
jakesz28's Avatar
I have not ordered any caps yet. I'm just trying to decide if I want to tackle this. But when I was gettting prices for the machine work the guy noticed where I worked and he gave me the idea of doing it myself to help cut cost.
So you say buy the 10* program flat caps and cut the block register to fit the cap.
Thanks for the info.
Old Sep 30, 2007 | 02:03 PM
jakesz28's Avatar
Do you have a part number?
Item Number Category > Part Type > Manufacturer > Engine Type > Specific Engine Type > Part Family
Description Photo Price Quantity
SB350C12 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small block 350 stepped caps with angle bolts for 2 bolt block with stock register $226.13
SB350C12F Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small block Chevy 350 flat bottom caps with angle bolts for blocks where stock dipstick usage is required. $226.13
SB350C22 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
Small Block 350 Chevy Splayed Center Caps with 2-Bolt Register and 22 Degree Outer Bolts $226.13
SB350CFA Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 FLAT-BOTTOM SPLAYED CENTERS (3 CAPS) $226.13
SB350CFS4 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 FOUR BOLT REPLACEMENT CENTERS (3 CAPS) $226.13
SB350CSA2 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 SPLAYED CENTERS FOR 2-BOLT BLOCK (3 CAPS) $226.13
SB350CSA4 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 SPLAYED CENTERS FOR 4 BOLT BLOCK (3 CAPS) $226.13
SB350CSS2 Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 STRAIGHT STEPPED CENTERS (3 CAPS) $226.13
SB350F Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 350 FRONT $74.59
SB350F4B Chevrolet null > Main Caps > Pro-Gram Engineering > Small Block Billet > 350 > null
CHEVY 4 BOLT 350 FRONT $91.46
IS it this one? SB350C22
Old Sep 30, 2007 | 04:41 PM
Sb350c12f
Old Oct 1, 2007 | 02:41 PM
11secgen's Avatar
i know everybody hates ebay, but i got my splayed billit steel caps for $59.just throwing that out there.
Old Oct 1, 2007 | 02:43 PM
11secgen's Avatar
i know everyone hates ebay, but i got my splayed billit caps for my twobolt lt-1 for $59 brand new, from some circle track store on there.
Old Oct 3, 2007 | 03:14 PM
SSQATCH's Avatar
The list above is very misleading. I read that and started to freak out because the part number I ordered looks like it belongs to a 4 bolt block... The dotted line (-------) indicates the part number above and the description below. Example:
BELOW IS HOW IT SHOULD READ
Part number XXXXXXX1
Description for part number XXXXXXX1
BELOW IS HOW I READ IT AND IT IS WRONG!!!
Just an FYI,
TOM B
LeftoverChinese
Jan 14, 2024 03:03 PM
4586
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
