Replacing old lifters
Old Sep 25, 2007 | 12:31 PM
missetti's Avatar
Got a 350 chevy in my Landcruiser. A napa motor, thats been real good over the years. Got a lifter thats bleeding off after sitting all night. Will stop ticking after it warms up. Going to pull the intake and replace the lifters. Is there any procedure I need to follow, like running the rpms at a set RPM like breaking in a new cam? Or just set adjustment and fire the beast up? Nothing fancy, just an older Chevy with Hydrulic lifters, Kevin.
Old Sep 25, 2007 | 09:39 PM
MachinistOne's Avatar
You really should replace flat tappet cams at the same time as the lifters, but most of the time you can get away with it. Yes - you will need to follow the standard break-in procedure again to allow the lifter to wear in a little to the lobe without wiping it. You also need to use a diesel 15-40 at least for break-in because they are the only non-syn oils readily availible that will protect the cam during break-in. That or see if you can get some GM EOS at the dealership.
Old Sep 26, 2007 | 08:20 PM
rskrause's Avatar
Moderator
It's a risk, but the (presumed) wimpy springs and (presumed) non-aggressive lobes will help. GM Rotella (cheap) or Brad Penn Break-In oil are good options. I bet someone who is a real lifter expert could make some comment on the brand of lifter best for this situation. I seem to recall hearing something about that once.
Rich
Old Sep 26, 2007 | 11:05 PM
WS6T3RROR's Avatar
I always run the gm brand "hard foot" lifters that were run in taxi cabs and police cars, anything with lots of idle time. They usually work really well for me, I havent run a cam company lifter in about 8 years. Mostly because nearly all of them I have found to be junk for one reason or another its a long story, but thats what i suggest.
Old Sep 28, 2007 | 04:16 PM
missetti's Avatar
okay, thank you gentlemen, I'll look into the taxi lifters, and get some rotella 15-40 oil when I swap them out. I thought I would have to run them at a higher RPM to break them in. Gotten use to the roller lifters, been a long time since I've played with this older stuff. But I love my old Landcruiser, and I have gotten a great deal of enjoyment from it. One for slow, and 1996 Z28, for go, Kevin.
Old Oct 6, 2007 | 03:57 AM
1racerdude's Avatar
You need the GM zinc additive to break them in which most oils over the counter don't have now a days.
I would put some Marvel oil additive in it and run it for 500+ miles before I did all that work.
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
jayblev95
Dec 1, 2014 06:55 AM
